AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 10-02-2008, 11:28 PM   #1 (permalink)
Sony DAV-IS10 speaker cable question
I currently have an old LG LH D6230 dvd and 5.1 surround soundsystem.Am looking to upgrade to the Sony DAV-IS10.All my old wiring to the rear speakers is run under the carpet.Will I be able to use the old wiring on the Sony rear speakers and will I need to get any connection adapters,or is it just a case of cutting the wires? I really don't want to have to rip the carpet up!
Also if I have to cut the wires,will I lose any sound quality?
simon_murray03 is offline   Reply With Quote
Old 10-02-2008, 11:32 PM   #2 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
Re: Sony DAV-IS10 speaker cable question
Originally Posted by simon_murray03 View Post
You will just need to join the Sony plugs at the Sub connections, you wont lose sound quality
kentish_lad is online now   Reply With Quote
Old 10-02-2008, 11:35 PM   #3 (permalink)
Ok so I just cut the Sony wires and join them to my old LG wiring? Any type of connectors needed to join the wiring or will insulation tape do?
Old 10-02-2008, 11:45 PM   #4 (permalink)
Yes that would suffice or you could use cable connectors that crimp up with a pair of pliers for a more secure join
Old 10-02-2008, 11:50 PM   #5 (permalink)
Ok thanks for your help,on a seperate note,I want to incorporate my PS3 into all this ,am I right in the below connections,this would be with the Sony DAV-IS10
1.PS3 to Samsung LCD HD ready TV through HDMI cable
2.TV to Sony DAV-IS10 through HDMI cable
3.PS3 to Sony DAV-IS10 through optical lead for the audio
Would that work?
Old 10-02-2008, 11:51 PM   #6 (permalink)
Would that work?
Spot on mate
Old 10-02-2008, 11:53 PM   #7 (permalink)
Thanks mate,will probably purchase the Sony later on in the year,will just have to put up with the audio from the Samsung LCD for my PS3 in the mean time,its probably not too bad!
Old 10-02-2008, 11:56 PM   #8 (permalink)
Just get a decent demo before you buy, the sounds not everyones cup of tea
Old 11-02-2008, 8:13 AM   #9 (permalink)
Thanks: Gave 8, Got 3
Hi Simon
No need to cut and join as Kentish Lad suggests. You could use your old wiring.
You can remove the speaker cord from the connectors that go into the sub.
Best thing to do is download the instruction PDF file from Sony website.
RS4Fluff
PS I've got a copy of it if you can't find it.
RS4Fluff is offline   Reply With Quote
Old 11-02-2008, 11:35 AM   #10 (permalink)
Originally Posted by RS4Fluff View Post
Hi Simon
RS4Fluff
Looking at the manual the connectors can be removed from the cable
Old 31-03-2008, 2:39 PM   #11 (permalink)
Thanks: Gave 5, Got 0
I understand the speaker wire that comes with the DAV-IS10 is 22 gauge wire. I have pre-existing 16 gauge wire already installed right where I want it to be.
I know I can remove the tab on the end and from the speaker.
My question is, will the speaker and the connection tab....and the wall mount support the width of a standard 16 gauge wire??
Side note: I am looking to buy the Sony 40W3000 and the DAV-IS10 along with a PS3.
Any advice on that setup?
RSHERMAN112 is offline   Reply With Quote
cable, davis10, question, sony, speaker
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sony DAV-IS10 bigears All-in-one Systems 10 03-11-2008 1:49 PM
Sony DAV IS10 £370 - why?? gurjy All-in-one Systems 4 11-05-2008 12:39 PM
sony dav-is10 gear_1052000 All-in-one Systems 1 24-01-2008 2:52 PM
Sony DAV-IS10 - Looking To Buy... UKGDJ All-in-one Systems 3 30-12-2007 2:31 AM
Sony Dav X10 2.1 or Dav IS10 5.1 mthompson All-in-one Systems 1 30-09-2007 3:28 PM
AV ForumsOptimised for Firefox.
