AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 08-02-2008, 4:08 PM   #1 (permalink)
Pirate!!'s Avatar
Thanks: Gave 353, Got 462
Cool 1080i Samsung 32" LCD TV - Recommend a HTIB Please
Ahoy!
I wish to replace my existing Panasonic SC-HT500 DVD/home theatre kit with an upscaler unit. I need best advice for a set-up to £250.00 (max).
My Samsung LE32R41BD 32" LCD TV is 1080i standard according to the user manual, though it has been firmware upgraded, but I know not what the upgrade did!
The TV does NOT have an optical connector, but does have one HDMI socket apart from the usual stuff.
I have been looking at a Panasonic SC-PT450EB-K (multi-region), though the R2 version can be bought via Amazon for £129.99 delivered! I do need multiregion and 500w minimum output in 5.1.
I would really appreciate guidance and if possible, links to reviews and tech specs.
Thanks in advance.
Sony A700, HVL-F42AM, VG-C70AM, Sigma 1.4x EX APO TC (for sale), Min 24-85, Tamron 90 f/2.8 Di Macro, RedSnapper tripod, Wii, Sky+, Dell Vostro 1500 flickr Darckr Jetphotos
Pirate!! is offline   Reply With Quote
1080i samsung 32, htib, lcd, recommend
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Recommend a wall mount for my 26" samsung lcd (le26r74bdx) king blaze LCD Brackets and Mounts 1 03-01-2008 8:11 PM
Recommend a Wall Bracket for Samsung 26" LE26S86BDX/XEU Kingster IOM LCD Brackets and Mounts 1 06-08-2007 11:10 AM
Can you recommend a "Signal Booster" / "Ariel Amplifier" for freeview Gadget Daddy Freeview 5 15-04-2006 11:22 AM
Samsung 32" 1080i CRT TV ? mjr600 High Definition TV Hardware 31 29-01-2006 1:46 AM
looking to buy a 23" LCD - which do you recommend - Samsung LE23R41B looks good woodentom LCD Televisions 0 13-12-2005 4:36 PM
AV ForumsOptimised for Firefox.
