AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 06-02-2008, 8:55 PM   #1 (permalink)
Thanks: Gave 11, Got 1
looking for home cinema system - for panasonic th-42px70
Hi! looking for home cinema system - ideally would like panasonic but will look at alternatives!
- i would like upscalling dvd (as i have heard this is good).
- also only need small speakers - only really need two satelite, centre speaker, and sub (small sub to fit in unit) - but will accept four satelite, or two wireless tallboys.
- power isn't too important just good sound quality
- using it for sky+, wii, ps2, and dvd.
Thanks for your help in advance!
It is much appreciated.
MDickson is offline   Reply With Quote
Old 06-02-2008, 9:18 PM   #2 (permalink)
Thanks: Gave 8, Got 21
Re: looking for home cinema system - for panasonic th-42px70
Panasonic SC-PT 850
anditsinthere is offline   Reply With Quote
MDickson (06-02-2008)
Old 06-02-2008, 9:25 PM   #3 (permalink)
thanks for the suggestions - but is it not four tall speakers?, which i'm afraid wont suit the layout of the room.
i have heard good reviews about it though, especially with the panasonics.
Any other suggestions, please?
Thanks!
Old 07-02-2008, 9:55 PM   #4 (permalink)
Think i have narrowed my search to:
pioneer dcs-363;
phillips hts6510
does anyone have any views on these? or anything better they can suggest?
also can you by a converter for opticals? for these systems
Old 13-02-2008, 12:18 AM   #5 (permalink)
Thanks: Gave 5, Got 0
Thanks!
The speakers of the 850 can be separated from the towers for wall mounting if that helps you make a decision.
9112233 is offline   Reply With Quote
Old 13-02-2008, 6:28 PM   #6 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
..........or mounted on the stand without the extention for table top mounting
kentish_lad is online now   Reply With Quote
cinema, home, panasonic, system, th42px70
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic TV and Home Cinema System clive lee All-in-one Systems 4 19-11-2007 8:28 AM
Panasonic Home cinema system- which one? Cinemaman All-in-one Systems 0 13-08-2007 11:41 AM
Panasonic 5.1 Dolby Digital Home Cinema DVD Player vs Sony 5.1 Home Cinema System shuRe Speakers 0 04-07-2007 7:58 PM
panasonic home cinema system help brian.w Speakers 2 11-12-2005 12:51 PM
AV ForumsOptimised for Firefox.
