AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 06-02-2008, 5:48 PM   #1 (permalink)
Thanks: Gave 20, Got 33
home cinema with 2 opitcal inputs?
Hi, im looking to buy a new all in one home cinema kit and would like to know if theres any that have 2 optical inputs?
the reason i would like 2 is that the toslink switches in my opinion are garbage and when i connect my xbox 360 and then switch to the ps3 it turns into a nightmare
my optical input on my samsung has given up the ghost with the constant switching of cables and thats why im asking for help in here
thanks in advance
tony
bulletmagnet is offline   Reply With Quote
Old 06-02-2008, 9:16 PM   #2 (permalink)
Re: home cinema with 2 opitcal inputs?
anyone seen any?
Old 06-02-2008, 9:27 PM   #3 (permalink)
tvdavid's Avatar
Thanks: Gave 14, Got 45
The Sony HT-DDW890 has 2 also there a coax as well.
Its not a bad system.
Toshiba 42X3030DB , Samsung LE32R51BD , THOMSON DSI8215 , Sky Entertainment Pack , Pioneer VSX 817 , Sony HT-DDW890 , Sony VAIO AR61E , LG DR 175 , Xbox 360 , N95 on 3 , Sky Max 16mb.
tvdavid is offline   Reply With Quote
Old 07-02-2008, 8:22 AM   #4 (permalink)
can anyone recommend a decent optical switch?
these ones are poor
http://www.maplin.co.uk/Module.aspx?...ptical&doy=7m2
Old 07-02-2008, 4:30 PM   #5 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
these ones are poor
tvcables.co.uk @ £7.99:
http://www.tvcables.co.uk/cgi-bin/tv...ml?id=wut6odWA
kenable.co.uk @ £3.76:
http://www.kenable.co.uk/product_inf...243928c10bd975
they are all similar though,but both of those are a lot cheaper than the £14.99 that maplin want.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
Old 07-02-2008, 9:54 PM   #6 (permalink)
would one of these work if i bought a setup with only 1 optical
http://www.maplin.co.uk/Module.aspx?...switch&doy=7m2
if i linked that to the amp could i connect both my ps3 and 360 to it and just press the button to change the sound ?
sorry but im not very good with these things and i broke my optical socket on my last one with keep swapping cables
Old 08-02-2008, 6:26 PM   #7 (permalink)
RottenFox's Avatar
yeh,that would work,but really,the above options,are better i would say.
far cheaper for one,and for another,you dont need a added converter,just a switch.
cinema, home, inputs, opitcal
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic 5.1 Dolby Digital Home Cinema DVD Player vs Sony 5.1 Home Cinema System shuRe Speakers 0 04-07-2007 7:58 PM
For Sale: Sony DAVS-550 Home Cinema + Panasonic SCHT1500 Home Cinema HDD & DVD Record jamezm Archive : Completed Business and Expired Threads 38 01-05-2007 10:21 AM
Home cinema surround with 2 optical inputs sage All-in-one Systems 3 31-08-2006 10:46 AM
Connecting Home Cinema via TV inputs?? lettuce Integrated AV Amplifiers and Receivers 0 12-03-2005 12:21 PM
Reviews of Hitachi 42PD5X00 in Home Cinema Choice & What Home Cinema Lewdannie Home Cinema Magazines, Industry and Jobs 6 26-05-2004 2:05 PM
AV ForumsOptimised for Firefox.
