AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 06-02-2008, 10:49 AM   #1 (permalink)
Panasonic SC-PT850
Ok thinking of buying the Panasonic SC-PT850 system, it's my first ever home cinema system and i'm a complete newbie dim wit....
I want to connect my system up to my samsung lcd tv, xbox 360 and sky+ is this system good enough to do all this or can anybody suggest a better system for this type of cash ???
If it is a good enough system what cables do i need to buy when i buy the system, i guessed a hdmi cable and optical cable, is that right or do i need more ?
Thanks for comments in advance.
ianeverton is offline   Reply With Quote
Old 06-02-2008, 11:17 AM   #2 (permalink)
Thanks: Gave 1, Got 1
Re: Panasonic SC-PT850
I have this system and personally i think its great. You will need a toslink cable to connect up your 360 for surround sound & a HDMI cable aswell. If your sky + box has a optical out you will need a toslink splitter and another toslink lead.
simobbck is offline   Reply With Quote
Old 06-02-2008, 11:34 AM   #3 (permalink)
When you say toslink cable do you mean optical cable ? would the HDMI cable be to connect up the TV ?
Are the rear speakers wireless on the system ?
Sorry about all the questions but as I said I'm a complete novice !!!
Old 06-02-2008, 2:01 PM   #4 (permalink)
yea optical cable - there about £3 on ebay. HDMI lead will go from the pt850 to your TV.
No the speakers are not wireless.
Old 06-02-2008, 3:29 PM   #5 (permalink)
Cheers mate
I also have one eye on the Sony DAV-DZ830 system, in peoples opinion which is the best system ???
panasonic, scpt850
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic PT850 - how two connect to TV Blacktigger72 All-in-one Systems 19 25-01-2008 1:42 PM
panasonic TX-32LMD70 AND SC-PT850 kingrollo All-in-one Systems 3 19-01-2008 8:25 PM
Panasonic SC-PT850 SavXtreme All-in-one Systems 2 13-01-2008 7:22 PM
Panasonic SA-PT850 Hack kcmaxwell DVD Player Hacks 1 02-01-2008 10:11 PM
Panasonic SC-PT850 Weirdoo All-in-one Systems 1 12-04-2007 11:33 AM
AV ForumsOptimised for Firefox.
