AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 04-02-2008, 5:07 PM   #1 (permalink)
Thanks: Gave 1, Got 2
all in one system with divx from usb?
Can anyone recommend a player to me? I was going to go for Philips 3154 system but i read a review it cannot play divx from a usb hard drive? Is this correct?
I have a budget of around £300+... I want small speakers... Im downgrading from separates as my floor standing speakers are too big and need to compact things in my flat.
My intentions are to have a system connected to a hard drive where i can play media files(avis, mp3s) straight off the hard drive... selecting it on the tv. Usually i would play them through vga cable on my laptop... but it will be at the opposite side of the flat now... I dont really want too many seperates kickin about so an all in one would be ideal... Dont fancy having DVD, AMP, MEDIA STREAMER(like popcornhour) all connected... perhaps i just need a wireless media streamer and the philips system?
Any ideas?
gram333 is offline   Reply With Quote
Old 04-02-2008, 5:59 PM   #2 (permalink)
Rob_Meister's Avatar
Thanks: Gave 70, Got 38
Re: all in one system with divx from usb?
The Samsung HTX30R is well within your price range and supports play back of Divx files etc, when external HDD's are connected to the front USB host. Only slight niggle is navigation; as the order of files seems to jump about a bit and can sometimes prove difficult to find what you want amongst a lot of files.
This will do what you want, but you may choose to go for a higher spec'd system. Athough it does also include HDMI upscalling and optical input, so decent for £200!
Rob.. PSN: RobMeister88 | XBL: RobMeister87
Bedroom Setup: Optoma HD70 | Pioneer VSX-AX2AS | PS3 | Xbox Elite | Sky HD | Vista Ulitmate Media Centre | Varilight Remote Dimmers | My bedroom setup
Rob_Meister is offline   Reply With Quote
Old 08-02-2008, 11:50 AM   #3 (permalink)
cheers for the reply mate... i like that one too!! Cheers!!
Would you go for it over the Pioneer DCS-363??
Old 08-02-2008, 4:55 PM   #4 (permalink)
gmp
Thanks: Gave 26, Got 19
Worth a look in online user manuals (if available) before you order. I was planning to use my LG502sh in exactly the same way as you until I discovered it cannot properly read hard drives or even 8gb usb stick if there are more than 999 individual files (eg album tracks) on drive. In fact I'm still not sure it could read 1/2 that amount properly. Wish I'd read the manual before I bought it No random play function even if you have a limited number of files to access via USB so you need to select play list each time
Still when laptop plugged into 502 the music stills sounds pretty good.
gmp is offline   Reply With Quote
divx, system, usb
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
DivX palyer and surround sound system dhiggs007 Interconnects, Speaker Cables and Switches 1 15-01-2008 4:46 PM
All-in-one system, DVD, DivX, DAB, HDMI, 5.1 DTS, USB under £400? Richdog All-in-one Systems 3 05-11-2007 11:29 AM
DivX System Question reddeviluk DVD Players (Standard Definition and Upscaling) 4 27-10-2007 7:45 PM
Panasonic system questions - Divx & Audio andyfr All-in-one Systems 3 07-10-2005 4:41 PM
For sale: All in one system., divx, xvid,amp, decoder speakers evolution400 Archive : Completed Business and Expired Threads 10 01-09-2005 10:25 AM
AV ForumsOptimised for Firefox.
