AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 04-02-2008, 2:50 PM   #1 (permalink)
wireless all in one system (help)
hi , im looking to buy a system with wireless rear speakers , my connections will be - xbox 360
virgin +
i have been looking at Sony DAV-DZ830W . can anyone give me advice or review on this or any simlar systems . also can i connect through optical using a toslink for the above .. thnks new to this if it sounds a bit daft .
devilmen is offline   Reply With Quote
Old 04-02-2008, 3:17 PM   #2 (permalink)
Thanks: Gave 4, Got 946
Re: wireless all in one system (help)
Virgin+ requires an optical input as does the XBOX, the Sony has one optical input only so without adding optical switches (nasty) you are stuck.
As for wireless you do realise you will require a power point and there will be a wire between the rear speakers, so for all the qauilty issues and hassle you would be better looking at a 5.1 system that a has wires and more optical inputs. I doubt the Virgin and XBOX will be the last items that you get and need optical connections for?
Andy98765 is offline   Reply With Quote
Old 04-02-2008, 3:24 PM   #3 (permalink)
thanks andy .. i was just going for wireless because of the wife , think i will look at wired ones though and hide cables with trunking . have you any advice on a good all in one system around £350 or lower preferably with tall speakers
Old 04-02-2008, 3:47 PM   #4 (permalink)
I am not the best person to advise on a all-in-one system, hate them.
They can not be upgraded.
One bit goes wrong it means throw it ALL away.
In flexible.
Useless connectivity, need I say more.
If I had your money to spend I would be looking at something like this
http://www.pixmania.co.uk/uk/uk/5420...ema-syste.html with a upscaling DVD player http://www.pixmania.co.uk/uk/uk/5447...vd-player.html any part is replacable/upgradable has good connectivity. Connect DVD player with Digital co-ax and the XBOX and Virgin with optical cables.
http://www.yamaha-uk.com/pdf/product...ns/RX-V361.pdf you can even connect a Blu-Ray player which has Dolby HD to the 5.1 direct inputs, trying doing that on a all-in-one. Just add a set of stands from Argos for the speakers.
Old 04-02-2008, 5:04 PM   #5 (permalink)
thanks andy , think i will go for your suggestion / like you say plenty of options for future , one thing what cables would i need and how would you connect them.
panasonic viera 42 " tv 2 hdmi connections
v + box hdmi connection
xbox 360 / goin to use this as dvd player aswell
thanks for your help .
Old 04-02-2008, 7:41 PM   #6 (permalink)
XBOX dependant on which one is HDMI or Component to TV for video, Virgin + is HDMI.
For sound and connections to the AV amp then optical cables, one for each for full Dolby Digital dependant on sound track, and for basic TV sound, i.e. Freeview/analogue TV then a stereo phono cable to the AV amp, but the AV amp needs to be switched to Dolby pro logic (pretend surround), but do check TV connections first.
system, wireless
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Which wireless system daisy duck All-in-one Systems 1 05-12-2007 5:42 PM
Wireless 5.1 system for use with 360? RandomLee Xbox 360 10 26-03-2007 10:43 AM
For Sale: High End PC -- Mid Range PC -- Sapphire X800XL -- GeForce 6200A -- Top of the line 17" monitor -- PC 5.1 Speaker System -- Creative 7.1 Sound Card -- Wireless Keyboard & Mouse -- 2 x Wireless Network 802.11g Cards -- Portable Photo rozzr Archive : Completed Business and Expired Threads 60 14-06-2006 2:15 PM
What wireless All in One System are there? ash All-in-one Systems 2 15-11-2005 7:39 AM
Wireless System castrol All-in-one Systems 2 09-09-2003 9:30 PM
AV ForumsOptimised for Firefox.
