AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 16-01-2008, 10:05 PM   #1 (permalink)
Thanks: Gave 4, Got 0
Question Am I asking too much for £200 systems?
Hi - hope someone can guide me here, as I seem unable to find anything that fulfills all my requirements for an all in one home theatre system to replace my Sony DAV S550...
Should have;
  • integral DVD player
  • main unit to be 'long' rather than 'tall'
  • small speakers rather than the stupid tallboy things
  • 750W or greater
  • HDMI connectivity
  • Optical connectivity (for PS2)
  • 5.1 channels
  • Digital Media Port (or similar) to connect my iPod
  • Radio tuner
  • 'auto setup' as per a lot the Sony 'Digital Cinema Auto Cariblation'
  • ideally nice discrete silver speakers (accept I may be on a loser here)
  • approx £200 (+/- 10%)
I looked at the Sony HTSS1100, but it doesn't have an integral DVD player (which means I'd have to buy another bit of kit!), and the Sony DAV-DZ203/231, but that doesn't have the optical input for my PS2.
Should I;
  1. just use my PS2 as a DVD player (eventually upgrading to a PS3) and go for the HTSS1100;
  2. or should I go for the HTSS1100 and buy an add-on DVD player (recommendations please);
  3. or do I go for the DAV-DZ203/231 and lose the optical connectivity option;
  4. or is there a better, more close matching bit of kit out there that I am missing??
Help me please...
Skinnera is offline   Reply With Quote
Old 18-01-2008, 9:50 PM   #2 (permalink)
Re: Am I asking too much for £200 systems?
...anyone...?
Old 19-01-2008, 10:20 AM   #3 (permalink)
Thanks: Gave 3, Got 3
A couple to consider...
I'm probably going for the Samsung HT-X30
No Auto Setup, but does upscale DVDs. Hard to find at the moment, but try:
https://www.komplett.co.uk/k/ki.aspx?sku=333670
http://www.digital-fusion.co.uk/Inu_...p?ref=11224898
http://www.e-plenish.com/pgProduct.c...BBD89AD9DAE6EC
Samsung HT-TX35R/Samsung HT-X30R
Jamo JA-S502HCS51
Looks great, but no Optical in (does have digital coaxial in tho). Is a DVD player even if it isn't clear. You can check the manual here:
http://www.jamo.com/Default.aspx?ID=...roductID=17833
Best price is on Play:
http://www.play.com/Product.aspx?r=E...bc0d51c86d492#
They do exist, but finding them on the internet is much harder than it should be. Good luck!
NiallWaller is offline   Reply With Quote
Old 21-01-2008, 7:48 PM   #4 (permalink)
Thanks for the pointers, I'll take a look.
I'm veering towards getting the HTSS1100 and hooking it up to my PS2 for playing DVDs - although as the fan is a bit noisy, I'll eventually swap it out for a PS3.
That seems to make sense - why have 2 bits of kit when I don't need them...?
systems, £200
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sub for 2 systems martinoslice Subwoofers 1 28-12-2007 2:29 PM
All In One Systems.... Trem All-in-one Systems 6 14-07-2007 11:47 PM
All systems are go! Ashman666 PS3 17 06-02-2007 11:04 PM
PA systems karkus30 Music 7 07-01-2007 4:58 AM
Need help,2 systems under £100 each barrykil Hi Fi Systems and Separates 3 02-05-2005 4:48 PM
AV ForumsOptimised for Firefox.
