AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 16-01-2008, 7:40 PM   #16 (permalink)
Welsh Whirlwind's Avatar
Thanks: Gave 53, Got 176
Re: Very disappointing picture from DAV-IS10 or is it the TV?
Originally Posted by captainsensible View Post
Doubtful, as the IS10 only upscales to 1080i and not 1080p
I stand corrected!
Welsh Whirlwind is offline   Reply With Quote
Old 17-01-2008, 10:30 AM   #17 (permalink)
Thanks: Gave 2, Got 2
Originally Posted by Welsh Whirlwind View Post
Does the IS10 have a 'Dynamic range compressor' or 'D.Range' - My Sony HTSF1200 amp does have this option... It basically compresses the dynamic range of dolby digital soundtracks to allow you "to watch movies at low volumes late at night"
If you do then select 'COMP MAX'
I've trawled through the instruction manual (as for most men, this is something I never normally bother doing) and the limited menus and I can't find anything... it does have a 'night mode' which compressed the dynamic range, but this has to be positively selected off the remote. Perhaps this is just the way it is.
The only problem I have now is I haven't been able to update my Harmony 855 yet, so I'm having to deal with 3 remotes... amazing how quickly you egt used to a universal remote!
chris stott is offline   Reply With Quote
Old 17-01-2008, 9:56 PM   #18 (permalink)
EmArA's Avatar
Thanks: Gave 6, Got 4
Question Re: Very disappointing picture from DAV-IS10 or is it the TV?
Hi guys, dont want to start a new thread so I'm about to buy the Dav-IS10& i am just wondering if the Pic would be good on a Full HD Lcd Sammy? Or do i need to set it @ 1080i and not 1080P when playing Dvds?
I like the size of the speakers cause i dont have a lot of space in my living room. As i read most of u guys are amazed by the sound quality which is a good thing.
thnx in advance
cheers
SaMsUnG LE40F86/ Ps3/ Vaio Fe/SaMsUnG LE32R71(w)/ iPod 30&80 GB/ iPod Hi-Fi
EmArA is offline   Reply With Quote
Old 18-01-2008, 1:12 PM   #19 (permalink)
twe
Thanks: Gave 4, Got 3
hearing this at Comet I had to put the volume above 50 as well to listen to it properly....
Am guessing its just the lower output from the tiny speakers.....
twe is offline   Reply With Quote
davis10, disappointing, picture
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sony DAV-IS10 bigears All-in-one Systems 10 03-11-2008 1:49 PM
Dav IS10 Set up help please fishingswampie All-in-one Systems 22 02-09-2008 9:52 PM
dav-is10 ukgeoff DVD Player Hacks 1 05-11-2007 6:26 PM
Panasonic NV-HS930B VCR - Disappointing Picture Quality J80FAB PVRs and VCRs 1 14-01-2007 1:28 PM
Disappointing picture quality Hitachi 42PD7200 vs Pioneer PDP436FDE tiggertimuk Plasma Televisions 6 17-11-2005 2:47 AM
AV ForumsOptimised for Firefox.
