AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 22-12-2007, 5:06 PM   #1 (permalink)
Samsung HT-X30 DVD Home Cinema
H E L P !
SAMSUNG HT-X30 DVD Home Cinema.
I am having a lot of trouble with the Audio Sync on this system. Playing a DVD all OK but trying to play anything else, including the TV through it, is impossible. The audio sync keeps going out and just won't "lock in".
Does anyone know a fix for this problem please? It seems to be in the software? Can it be sorted
cheddar-caveman is offline   Reply With Quote
Old 22-12-2007, 5:43 PM   #2 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
Re: Samsung HT-X30 DVD Home Cinema
dont use optical audio for connecting the tv,to the home cinema.
if your tv,has audio out phonos(red/white),use them instead,if you cant adjust the sync issues.
there was a firmware update for samsung tv's,but it works for some,and not for others.
as far as the surround system goes,no firmware updates for that though.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is online now   Reply With Quote
cinema, dvd, home, htx30, samsung
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Samsung HT -X200 Home cinema k.marks All-in-one Systems 1 02-01-2008 9:41 PM
Samsung Home Cinema + DVD Recorder cbbear All-in-one Systems 3 28-08-2007 7:08 PM
Connecting Samsung LE40R87 to Samsung Home Cinema HT-X200R & Evesham E-Box Plus jamiekbris LCD Televisions 0 06-07-2007 9:18 AM
Samsung HD860 + Home Cinema hardhousehead DVD Players (Standard Definition and Upscaling) 3 20-08-2006 12:22 AM
Samsung Home Cinema Kit, Comments? dallen All-in-one Systems 0 23-03-2006 8:19 PM
AV ForumsOptimised for Firefox.
