AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 18-12-2007, 7:11 PM   #1 (permalink)
Help!!!!!
hello
I need help i am trying to set up surround sound
i have: pioneer pdp-5080xd tv
sky hd box
pioneer dcs-363 surround sound
when i watch dvds on the sourround sound it works but when i want to have surround sound on the sky hd box it only comes out of 2 speakers when i have 5. i need help
i am doing this for my parents so i need really easy instructions on how to set this up.
please respond quick i need to do asap
thanks
tom16 is offline   Reply With Quote
Old 18-12-2007, 7:15 PM   #2 (permalink)
sbowler's Avatar
Thanks: Gave 123, Got 436
Re: Help!!!!!
The output from the Sky box, the audio that is, needs to be either optical or coaxial. These sockets should be marked on the back of the sky box. If the audio output is via the two phono connectors or just scart leads then you will only get two channels. The optical socket is square and black it will be marked optical out. The coaxial socket is round and orange and will be marked coaxial out. You need a special lead for optical out, but for coaxial you can use any phono lead.
My flickr Pentax K10D Sigma 10-20/24-135/70-210/Pentax 50mm f1.4/Sigma 24-70mm DG-EX
MyA/V
"Chance favors the prepared mind"
sbowler is offline   Reply With Quote
Old 18-12-2007, 7:32 PM   #3 (permalink)
Re: Help!!!!!
sbowler i did find much on the back of the box i have pm you so talk through there now anyone else
Old 18-12-2007, 8:52 PM   #4 (permalink)
Thanks: Gave 5, Got 3
Re: Help!!!!!
I always thought you only get sound out of 2 as the channels are only broadcast in 2.1 mode, unless it is a movie or documentary which is in 5.1 then you get it out of all speakers.
This is why you get sound from dvds in 5 speakers as it is made in 5.1, and tv channels are only in 2.1 there for sound out of 2, could someone eles confirm this.
Sianba
sianba is offline   Reply With Quote
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
