AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 18-12-2007, 2:24 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Connection options for HDTV/PS3/Sky HD/Surround sound all in one system
I'm new to HD and want to find out the best options to connect the following.
Sony HD tv - KDL40X3500 (arriving friday)
Sony all in one surround system DAV-IS10 (sitting in its box)
Sony PS3 (under the christmas tree)
Sky HD box (on order)
Thanks in advance
Tony Goldsmith
Tony Goldsmith is offline   Reply With Quote
Old 18-12-2007, 2:31 PM   #2 (permalink)
Ryu
Ryu's Avatar
Thanks: Gave 9, Got 10
Re: Connection options for HDTV/PS3/Sky HD/Surround sound all in one system
3 HDMI sockets on that TV I think, so HDMI for every one of the three.
SKY HD comes with the HDMI lead.
You may need to buy 2 more for the PS3 and DVD player.
Ryu is offline   Reply With Quote
Old 18-12-2007, 2:50 PM   #3 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
dont forget optical and coax audio leads for the ps3,and the sky,as you wont get surround from sky with hdmi.
so connect the ps3,with hdmi to the tv,same with skyHD,then connect the ps3's optical audio out,to the surround system,and the skyHD audio out,to the surround coax audio in(if your sky box has a coax audio out).
if it doesnt,you will need another optical lead,and one of these:
http://www.kenable.co.uk/product_inf...243928c10bd975
or these:
top one is a manual switch,bottom is an auto setup.
i would go for the top one,as you may want to connect the tv's optical out to the system as well.
so all in,you will need:
1 hdmi for the surround system - to tv.
1 hdmi for ps3
1 hdmi for sky(might come in the box).
1 optical for ps3
1 optical/coax audio lead for sky.
1 optical for tv- to surround system(possibly).
1 optical for switch-to connect to the surround.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline   Reply With Quote
Old 18-12-2007, 3:07 PM   #4 (permalink)
Thanks for the excellent response, probably saved me many hours of head scratching
Tony G
connection, hd or surround, hdtv or ps3 or sky, options, sound, system
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Swisstec 19" With Bad Sound Quality - Please Please Help With Surround Sound Options Vmanstu LCD Televisions 0 17-10-2007 9:16 PM
Wireless Surround Sound system, minus DVD player. Any options? Hrochnick All-in-one Systems 4 19-09-2007 11:23 PM
£300 for surround system. options/upgrades/packages ukbandit Speakers 5 22-07-2007 5:48 PM
Laptop to HDTV -- best connection options? guacamolefoo Laptops and Mini PCs 6 23-06-2004 4:08 PM
DTS for a Newbie to Surround sound options hendo25 Integrated AV Amplifiers and Receivers 4 06-01-2002 6:37 PM
AV ForumsOptimised for Firefox.
