AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
Closed Thread
LinkBack Thread Tools Display Modes
Old 17-12-2007, 12:44 PM   #1 (permalink)
Help before I throw it!! HT-TX35R
Just Bought Evan Almighty in HD format and the unit won't play it, it just keeps on searching but then comes up with disc empty!?!?!? I have trawled through the instruction manual but thats no help either!!
djcevo is offline
Old 17-12-2007, 12:46 PM   #2 (permalink)
Thanks: Gave 7, Got 7
Re: Help before I throw it!! HT-TX35R
that unit cant play HD dvd's
Media PC - Q6600 w AK-960E - GA-G33M-DS2R - 4GB OCZ - HD3850 PCS eXtreme 512MB - Auzentech HDA X-Plosion 7.1 DTS - 3 Tb Storage - LG 37" 37LG5000 1080P - NZXT Rogue (Black) - Vista Ultimate
Brynmiller is offline
Old 17-12-2007, 1:05 PM   #3 (permalink)
Thanks: Gave 99, Got 63
what ?
Calibrate to Appreciate
Phill1978 is offline
Old 17-12-2007, 1:07 PM   #4 (permalink)
Thanks: Gave 6, Got 9
how many people have done this now ? heads should roll at retailers,film companies and manufactures !!!!
it should be made easy for the consumer,blueray isn't to bad but people are buyin hd discs for there hdmi dvd players thinking they will play when they won't.
jtfab75 is offline
Old 17-12-2007, 1:16 PM   #5 (permalink)
we all said this would happen.
got rid of my 40" philips under the premis that i was missold it says fullHD 1080p on the box but its 768p native res and accepts 1080p throught hdmi downscaled
i swaped for a new Cineos 1080p 47" philips now
Old 17-12-2007, 1:18 PM   #6 (permalink)
btw djcevo there should be a SD layer on that disc (well appears to be on my blueray and hddvd disc) so at least you could switch layers and upcale to 1080i or 720p.
id take the unit back, there are currently NO blueray or HDDVD all-in-ones although philips and sony have some coming out soon
how compatible they will be is anyones guess
Old 17-12-2007, 5:39 PM   #7 (permalink)
RottenFox's Avatar
Thanks: Gave 177, Got 1,036
movies say "hd-dvd" or "blu-ray" on the box,and the HT-TX 35R,is a dvd player,and says in the box/manual what it plays.."dvd's",nothing more nothing less,and no mention of the words "hd-dvd" or blu-ray.
i feel that the OP made a mistake he wont make again,and its nothing to do with manufacturers,or marketing.
some basic checking is all that would have been needed,as its in the consumers best interests to check out information,not the companies to lead you there.
closing this topic.
XBL/PSN Gamertag - RottenFoxBreath Wii Code - 5320 0184 6511 5759
- The views i express are my own,and in no way represent the views of AVForums or affiliates -
RottenFox is offline
httx35r, throw
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Samsung HT-TX35R Sq1rr3ll All-in-one Systems 2 06-01-2008 6:19 PM
Wireless for HT-TX35r djcevo All-in-one Systems 1 03-11-2007 11:12 AM
Sky+ and HT-TX35R gr1340 All-in-one Systems 4 16-07-2007 9:18 PM
Optimum image quality - short throw with maximum zoom or long throw with no zoom? Brofeld DLP, LCD and D-ILA Projectors 11 25-08-2006 6:43 PM
Short throw vs. Long throw sapkan DLP, LCD and D-ILA Projectors 3 06-10-2004 12:15 PM
AV ForumsOptimised for Firefox.
