AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 16-12-2007, 6:08 PM   #1 (permalink)
Panasonic SC-PT850E-K and divx subtitles
I was planning to buy such a system but I can't seem to find any definitive answer to the question: does it play divx subtitles. Can anyone who has this system tell me that? Or, if the answer is know, recommend me another all-in-one in the same class (tallboy speakers, upscaling, optical input, good sound and picture, divx)?
Thank you.
nicuurs is offline   Reply With Quote
Old 16-12-2007, 7:48 PM   #2 (permalink)
Welsh Whirlwind's Avatar
Thanks: Gave 53, Got 176
Re: Panasonic SC-PT850E-K and divx subtitles
Thank you.
Can't tell you about the 850, but the lg hr902ta has everything you need and more, plus it definately plays back DIVX subtitles, see below:
DivX file requirement
Available resolution size: 720x576 (W x H) pixel
DivX file extensions: “.avi”, “.divx”
Playable DivX subtitle: “.smi”, “.srt”, “.ssa”,
“.sub (Micro DVD format)”,
“.txt (Micro DVD format)”
Playable Codec format: “DIV3”, “DIVX”, “DX40”,
“DX50”, “3ivx”, “MP4V2”, “MP4V3”
Playable Audio format: “AC3”, “PCM”, “MP3”,
“DTS”
The only problem is they're in short supply at the moment, I've been waiting on one to be delivered from Empire Direct for the past 3 weeks now and they're still unable to tell me a specific delivery date...
Welsh Whirlwind is offline   Reply With Quote
Old 16-12-2007, 7:59 PM   #3 (permalink)
Just had a quick look at the 850's manual and found this:
(Extension: “.DIVX”, “.divx”, “.AVI” or “.avi”)
• You can play all versions of DivX® video (including DivX® 6) [DivX video system/MP3, Dolby Digital or MPEG audio
system] with standard playback of DivX® media fi les. Functions added with DivX Ultra are not supported.
• DivX fi les greater than 2 GB or have no index may not be played properly on this unit.
• This unit supports all resolutions up to maximum of 720 x 480 (NTSC)/720 x 576 (PAL).
You can select up to eight types of audio and subtitles on this unit.
So yes, your in luck.
Old 16-12-2007, 8:50 PM   #4 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
UK version does not support DIVX, european models which do can be bought from Pixmania
kentish_lad is online now   Reply With Quote
divx, panasonic, scpt850ek, subtitles
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
DVD-HD870 DivX Subtitles tedmanowar DVD Players (Standard Definition and Upscaling) 1 15-09-2008 8:27 AM
Sony RDR HXD870/Subtitles DIVX tenten78 DVD Recorders, Recording and Media 7 16-12-2007 6:35 PM
panasonic dvd-s53 divx subtitles daimaku DVD Players (Standard Definition and Upscaling) 0 14-12-2007 6:31 PM
Panasonic DMR-EX85 & subtitles for Divx faca9 DVD Recorders, Recording and Media 18 01-04-2007 2:32 PM
Denon 1920 and subtitles on divx le'Dats DVD Players (Standard Definition and Upscaling) 1 07-01-2007 3:16 PM
AV ForumsOptimised for Firefox.
