AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 15-12-2007, 11:01 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Panasonic SC-PT850, TH42PX70, Virgin & WII
Right, here we go, complete amateur here so need some advice (and probably a kicking for stupidity!!) , I had a look thought some other posts and I think I知 getting there in terms of connecting everything together. Currently I have my Virgin Media HD box through HDMI to the TV, the Panasonic SC-PT850 sound system via the other HDMI, and the Wii via component. Problem is that I only get the sound from the PT850 when I watch DVD's and not when I知 watching tv or cable, which makes sense as I'm guessing I need to put the Virgin box through the PT850 and then into the TV but not sure how to do it, I致e seen other posts about using a digital optical cable but I知 not sure if that will solve my incompetence!!
Any advice would be greatly appreciated!!
javiebell is offline   Reply With Quote
Old 15-12-2007, 11:28 PM   #2 (permalink)
kentish_lad's Avatar
Thanks: Gave 25, Got 205
Re: Panasonic SC-PT850, TH42PX70, Virgin & WII
You need to connect an optical cable from V box to the 850
You need to connect phono cable (red and white) from wii to 850
To listen to V box press 'EXT-IN' on 850's remote until 'D-IN' shows
To listen to wii press 'Ext-IN' on 850's remote until 'AUX or 'TV' shows (which ever phono inputs you use)
Im assuming the wii doesnt have optical outputs but if it has you need to buy a splitter so you can connect both to the optical input on the 850
kentish_lad is offline   Reply With Quote
Old 16-12-2007, 12:05 AM   #3 (permalink)
Thanks: Gave 15, Got 218
The Wii has phono outputs as part of the component cable. You will need to buy a phono extension cable in order to take the cables to the cinema system however.
YellowSphere is offline   Reply With Quote
panasonic, scpt850, th42px70, virgin, wii
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic SC-PT850 differences NigelC All-in-one Systems 3 30-11-2007 6:58 PM
Panasonic 42PZ70 and SC-PT850 gcwebbyuk Plasma Televisions 3 14-11-2007 5:17 PM
Panasonic sc-pt850 problems DaveH29 All-in-one Systems 4 04-07-2007 10:26 PM
Panasonic SC-PT850 Weirdoo All-in-one Systems 1 12-04-2007 11:33 AM
AV ForumsOptimised for Firefox.
