| Re: Connecting a Virgin media box to Panasonic setup?
if the virgin box,had audio out,then it could be connected to the surround,and you would get audio that way,from cable tv,rather than using it the way you would have to now.
it may introduce some sound sync/lag..where the picture will either be ahead or behind the audio,but im sure the surround system will let you compensate for that.
i cant believe that the virgin box,doesnt have basic red/white analogue audio out though..
connect the surround to the tv,with hdmi,and connect virgin to the tv,with scart.
so you would feed the optical audio out/analogue audio out on the tv,to its corresponding audio in,on the surround.
bear in mind though,that the audio from the tv,will only be stereo,and you will have to pick a pseudo surround effect to make use of the rear speakers. a la stereo,with echo.
