Denon S102 Connectivity
Old 25-10-2007, 9:40 PM   #1
tjaayuk
Posts: n/a
Hi there - looking to buy a Denon S102. I've got a PS3, Sky Box and Toshiba TV with 2 HDMI connections. What is the best way to set up to ensure best sound and picture considering the Denon has no scarts and only 1 HDMI connections?
Thanks in advance for any advice.
Old 31-10-2007, 4:06 PM   #2
1,904, Level: 10
Points: 1,904, Level: 10 Points: 1,904, Level: 10 Points: 1,904, Level: 10
Thanks: Gave 8, Got 4
Re: Denon S102 Connectivity
I basically have the same setup, so any info would be very handy :D
Old 01-11-2007, 12:47 AM   #3
4,217, Level: 15
Points: 4,217, Level: 15 Points: 4,217, Level: 15 Points: 4,217, Level: 15
Thanks: Gave 1, Got 1
If you gentlemen have Sky HD then you'll have 3 HDMI to go into a TV with 2 HDMI slots. Then the best setup is
PS3 HDMI --> TV
Sky HD HDMI --> TV
S102 Component --> TV
If you really want to use all three HDMI you must buy a HDMI switch.
If you have Sky standard then you have no problem and you can hook Ps3 and S102 with HDMI and Sky with scart.
Old 01-11-2007, 8:36 PM   #4
1,904, Level: 10
Thanks Rbisuper. I have plumbed for this. I should get it tomorrow. I boned up a bit more now, so I have brought a QED Qunex OT digital optical Lead for my PS3 (that's all I'm worried about at this point).
Old 02-11-2007, 10:31 AM   #5
Korum's Avatar
7,623, Level: 20
Points: 7,623, Level: 20 Points: 7,623, Level: 20 Points: 7,623, Level: 20
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 182, Got 211
Just a bit of advice if you need to add more equipment with optical outputs. I've got an S301 which has the same inputs 1x optical/ 2x coaxial and I have 3 bits of kit with optical out only so I tried using a maplins optical to coaxial convertor and it all works perfectly, it's just a bit pricey as you have to buy a convertor, coaxial cable and optical cable for each of the 2 inputs.
What I can't understand is why Denon are still using 2 coaxials on their brand new smart series when most AV kit/games consoles are optical out only.They should have gone with 2 opticals instead.
andyb1080 (28-01-2008)
Powered by
 Latest popular product prices
Panasonic SC-XH50
5 prices from
 £99.99 Click to show/hide the offers
Sony DAV-TZ135
6 prices from
Samsung HT-D350
5 prices from
 £129.00 Click to show/hide the offers
Samsung HT-D450
4 prices from
 £139.96 Click to show/hide the offers
Samsung HT-D5000
5 prices from
 £143.98 Click to show/hide the offers
Logic3 Soundstage 5.1
2 prices from
 £166.59 Click to show/hide the offers
LG BDH9000
2 prices from
 £169.30 Click to show/hide the offers
Panasonic SC-HTB10
4 prices from
 £186.07 Click to show/hide the offers
 Updated February 13th at 2:30am. Prices include delivery.
[IMG] code is Off
