AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-10-2007, 5:14 PM   #16 (permalink)
Thanks: Gave 1, Got 0
Re: Sony RHT-G800 Home Cinema System/Stand
Hi. Does anyone know if the rht g800 is better than the rht g1000? If it is what things are better?
Thanks, Michael
Michaelw77 is offline   Reply With Quote
Old 04-10-2007, 4:34 PM   #17 (permalink)
Thanks: Gave 6, Got 9
Thanks, Michael
I do not think many will have both stands so info is scarce do a search on here for both models. I know the 1000 was close to £1K the 800 is nearer £700. First thoughts are the 800 is far the prettier.
G1000 - Sony unveils 5.1 home cinema speaker system built into Bravia TV stand
gary
gary350 is offline   Reply With Quote
Old 06-10-2007, 9:44 AM   #18 (permalink)
I am awaiting delivery of rht800.already got copy of manual but I am not sure how to connect my panasonic sky set top box which does not have digital optical output.can anybody please advise.
4857 is offline   Reply With Quote
Old 06-10-2007, 5:33 PM   #19 (permalink)
page 15
Connect this stand to a sat tuner using the INPUT OPT jack
If a sat tuner does not have the OPTICAL OUT jack connect this stand using the AUDIO jacks.
gary
Old 07-10-2007, 12:00 PM   #20 (permalink)
Thanks for your reply Gary.I presume the audio leads from Sky Box are connected to speaker connections labelled audio on the theatre stand and not audio under TV label.
The equipment I am having is as follows;
SONY BRAVIA TV KDL 32D 3000
SONY DVD RECORDER RDRHXD970
SONY THEATRE STAND RHT G800
Added to the above will be my Panasonic Sky Box which has no HDMI or optical digital connections.
Despite reading all the manuals I am still confused as to the OPTIMUM way to connect these 4 pieces of kit together to give best sound and vision.
I would be most grateful if you or anyone else [MATT from Sony?] could reply
soon so I can source any additional cables I may require.
THANKS
Old 22-10-2007, 9:32 AM   #21 (permalink)
Thanks: Gave 22, Got 20
Originally Posted by gary350 View Post
My LCD came yesterday and its now hitched up to the RHTG800 stand.
Sound quality is very good better than my Technics surround system but most of all it really looks good and easy to use.
Gary,
Can you confirm that the RHTG800 stand does pass 1080p over HDMI (not restricted to 1080i as stated in some review) ?
Regards,
Ole Willy Tuv
owtuv is offline   Reply With Quote
Old 25-10-2007, 12:02 PM   #22 (permalink)
Originally Posted by owtuv View Post
Gary,
Regards,
Ole Willy Tuv
The text below is taken from a review of the stand
While we're happy to see this stand handle HDMI signals, we are slightly put off by the fact that it will only pass through 1080i. This means if you own a 1080p TV, you won't be able to send a full HD signal to it from your Blu-ray or HD DVD player via this stand.
So the answer must be no
gary
Old 11-11-2007, 9:59 PM   #23 (permalink)
Thanks: Gave 3, Got 0
gary
Hi, I know the review says the stand will only pass 1080i but could they be mistaken? I say this because of a post on this forum that states 1080p 24fps through the stand.
http://www.avforums.com/forums/showt...ighlight=1080p
In addition if you look at the user comments on the review that quoted the 1080i limitations, there is a comment that it does pass 1080p:
http://www.cnet.com.au/hometheatre/h...9280487,00.htm
Last edited by cucumberuk; 11-11-2007 at 10:07 PM. Reason: Addition of more details
cucumberuk is offline   Reply With Quote
Old 12-11-2007, 1:08 PM   #24 (permalink)
Thanks: Gave 0, Got 11
Costco have these in or similar ones for £500 I think
s70rmp is offline   Reply With Quote
Old 21-11-2007, 12:12 PM   #25 (permalink)
I now have my stand set-up to feed a PS3 through the stand to a Sony 46W3000 via HDMI.
I can confirm that the stand passes 1080p/24fps.
Hope this helps to end the confusion.
Old 24-11-2007, 2:29 PM   #26 (permalink)
I have had this stand for a few weeks and overall I'm pleased with it, it looks good and passes 1080p through which is its best points I think.
I have had a weird problem of my PS3, the picture kept going off and coming back on (I got the PS3 going through the RHT via hdmi). I had the PS3 changed but after a day it did again, I heard the PS3 working though so I thought it could be the hdmi lead, I put the hdmi lead in I use for my Virgin+ and it worked but bizarrely if I plugged the original PS3 lead straight into the TV (Sony 4oW2000) the PS3 works normally, still can't figure that one out, I have brought a new hdmi lead and now use it through the RHT.
What I would like to know is it possible to set up the PS3 to use both a hdmi lead and optical lead to go through the RHT? Same for my Virgin+, HDMI for Pic and optical for sound? I have asked my local Sony centre and they have no clue.
Are there any settings available for the RHT-G800? It would be good to see how other people have it set up.
Also can you set the PS3 for 24fps manually? Everytime I try it stays on Automatic.
Dhekelian is offline   Reply With Quote
Old 02-12-2007, 7:10 PM   #27 (permalink)
Hi I was wondering if you can help since you have one
Im thinking of getting this stand , 40 or 46 tv, sky hd , ps3 and prob a dvd/hdd recorder (ive got an older sony one already)
Is the stand any good and sorry to ask a stupid question but why link the HDMI up to TV/Sky/PS3 if the stand is only for sound
would I be limted by the number of HDMI inputs for the stand (x2) since I would have 3 input units. And can the stand handle the optical inputs from the sky, dvd, and ps3 also?
The stand looks the business
Any advice welcome
andy1307 is offline   Reply With Quote
Old 03-12-2007, 11:36 AM   #28 (permalink)
Its best if you read the manual
http://pdf.crse.com/manuals/3093227221.pdf.
This is also worth looking at
PS3 no HDMI Sound only optical
gary
Old 09-12-2007, 3:44 PM   #29 (permalink)
Thanks: Gave 6, Got 0
got the RHT-G800 last week from costco for £470 inc vat
Doron is offline   Reply With Quote
Old 09-12-2007, 7:58 PM   #30 (permalink)
Thanks: Gave 1, Got 4
Any advice welcome
I have this stand with a Sony KDL40X3500, PS3, HXD-RDR970 & Sky+ and after some fiddling with the menu it works great.
Using HDMI control makes it all very easy once set up but my wife likes to use the Sky+ remote only but I cannot get the remote to control the volume, even though in theory it should work. I've tried the "0000" code but still no joy. Does anyone else have this problem or have they found a solution?
brighteyes is offline   Reply With Quote
cinema, home, rhtg800, sony, system or stand
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
