AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 16-06-2007, 11:05 AM   #1 (permalink)
Andyclockwise's Avatar
Thanks: Gave 5, Got 9
Jamo A102 HCS10 worth buying for speakers?
I am looking for a 5.1 lifestyle speaker system and noticed these can now be found on Ebay currently going for around £200. The main drawback would appear to be lack of HDMI. At this price they would appear to be a good buy for the speakers alone if partnered with a separate DVD and Receiver system providing the HDMI.
Any views? Any suggestions on a suitable Receiver to partner these speakers?
..This is going to test your mind, your head, and your brain.
Andyclockwise is offline   Reply With Quote
Old 16-06-2007, 1:38 PM   #2 (permalink)
2010's Avatar
Thanks: Gave 43, Got 39
Re: Jamo A102 HCS10 worth buying for speakers?
The new version of the A102 has HDMI output.
2010 is offline   Reply With Quote
Old 16-06-2007, 1:51 PM   #3 (permalink)
Yes, I know, but you have to pay nearer £499 for it. I have since found out you can buy the A10 5.1 speakers only for £235, so the EBAY price of £200 for the Speakers and non HDMI DVD/receiver may still be a bargain, especially if I can sell on the DVD/receiver and put the savings towards a good quality separates Receiver and DVD player.
Old 26-06-2007, 6:27 PM   #4 (permalink)
Thanks: Gave 13, Got 63
Only just noticed this thread, I brought the system off ebay for the bedroom for £189 and think its a cracking set up i think if you do get one and set it up you wont be too quick in getting rid of the receiver, The picture from component in to my 32"panasonic lxd60 is excellent as is the sound the speakers are very well built and would be a good buy at £200 on there own so go for it.
SVS 20-39 pc+/ M&K 850 LCR / M&K k-4 rears/ Harman kardon Avr8500/ Toshiba ep35 HD player/ Sony DVPNS 76H DVD PLAYER/ Roksan caspian m-series-1 cd player/ sky HD/ panasonic 42 pv500b/
Andywilliams is offline   Reply With Quote
a102, buying, hcs10, jamo, speakers, worth
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
