AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 19-04-2007, 1:46 PM   #1 (permalink)
Best Set up - AV359
Just got my first AV receiver, and spent a good few hours dismantling everything and re-cabling to include the receiver. So many connections is baffling me, and im hoping someone can maybe suggest the best set up.
The system has 2 optical inputs and 1 coaxial input, along with several audio inputs and 3 component inputs/1 output. Now I have Virgin +, currently connected up with HDMI, Xbox 360 via component, DVD recorder via scart. My plan is to connect all three via component in to the av receiver, to try reduce the amount of cables. Id then have optical coming from the DVD recorder and XBOX 360, and purchase an optical to coaxial converter and run virgin+ through this (none of my items have coaxial at present.
Is this the best way to hook it all up? Losing the hdmi i doubt would be a major problem due to the severe lack of hd on Virgin, and Im presuming a scart lead from Virgin+ to DVD recorder for recording programmes would be all thats required on top of above.
Scottttyyyy is offline   Reply With Quote
Old 19-04-2007, 2:07 PM   #2 (permalink)
Thanks: Gave 4, Got 946
Re: Best Set up - AV359
I would leave the Virgin connection as HDMI and run a fibre to the AV amp.
DVD recorder from what you are saying has component out, I would just make sure it is set to progressive out and the aspect of the DVD recorder made 16:9. Connect 5.1 leads to the AV amp from the Xbox and DVD recorder.
At least one of your three external components will need a co-ax output for 5.1.
The DVD recorder needs the audio set to bitstream out to get 5.1
Andy98765 is offline   Reply With Quote
Old 19-04-2007, 6:16 PM   #3 (permalink)
Thanks for the quick response. Could you confirm what you mean by 5.1 leads? The only option i have is optical out or standard audio out, which would be the red and white leads.....im a newbie at this
thanks again
av359, set
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
