AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 18-04-2007, 12:11 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Anyone Got The Lg Lh-t550tb ,help Req,d
Guy's,
Do any of you guy's have this system,I need a couple of questions answered as i have a couple of problems.
1) I am getting no sound at TV when connected through a scart plug.
2) My wife records her soaps etc on our dvd recorder in our bedroom which is DVD + discs but they will not playback on this LG system which says it will play dvd+ & - RW.Any ideas?
Any help much appreciated.
Graham
Easty is offline   Reply With Quote
Old 18-04-2007, 3:01 PM   #2 (permalink)
Thanks: Gave 2, Got 5
Re: Anyone Got The Lg Lh-t550tb ,help Req,d
For sound - try connecting to AV1 on tv instead of AV2. Also if you press AUX button then keep pressing sound button(On DVD remote) until Play Movie or Play Mtrx is displayed - see if thet helps. It should come out of all 5 speakers as mine does.
Playing recorded discs, i have read on other threads that you need to make sure that you finalize the disc you are copying.
Good Luck
JackL
JackL is offline   Reply With Quote
Old 18-04-2007, 3:51 PM   #3 (permalink)
Thanks JackL,I will give it a try,i do get sound from all five surround speakers plus woofer but nothing from Telly speakers
And i need to find some dvd +rw discs that will play in this machine as i have just read that it is disc fussy so it wont play the Philips DVD+RW discs i have at present.
Easty
lht550tb, req
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
