AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 18-04-2007, 10:42 AM   #1 (permalink)
ideal speaker wattage for 12ft x 15ft room !?
HI... newbie here !!
iv been renting a room (17ft x 20ft) in a house... & have seperates... though very dated now... only pro logic (kenwood kav3700... yep... dated !!) !!
i just bought a place & the living room is 12ft x 15ft... & my current set up is to bulky for my liking... so looking for something small & neat !!
so looking for a home cinema surround set up for SKY/PALYSTATION/DVD !!
i foolish bought the RICHER SOUNDS PANASONIC SCHT330... only to find out it does NOT do surround from external equipment... doh !!
but saying that... i am happy with their dvd surround sound... speakers seem more than loud/punchy enough... they are rated 65w each per small speakers & 75w for the sub... total output is 400w rms !!
so as a replacement... im looking at the ACOUSTIC SOLUTIONS DS355... seems to do what i need for external sources... but the speakers are rated 7w each per small speaker & 35w for the sub... total 70w rms... is this to low for my room... sounds like they are more suited as PC set up !?
anyone used these before in a similar sized room for MOVIES etc !?
anything else for this price range... upto £150... doesnt need to inc a dvd/tuner... i use my play station for dvds & sky for radio !!
i know you 'hard core seperate fans' will say they are better than alll in one... but my house party days are over... & need something simple & qauint !!
many thanks in advance... BRIAN
sound mate is offline   Reply With Quote
12ft, 15ft, ideal, room, speaker, wattage
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
