AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 16-04-2007, 1:10 PM   #1 (permalink)
Suggest replacement for JVC TH-A75R
My trusty JVC TH-A75R all-in-one started playing up with the dvd tray sticking now and then. Now it seems to have given up alltogether and just switches itself off when you insert a disc.
So two questions:
1. Can it be easily/cheaply repaired? If so how/where?
2. Can I get a suitable replacement and keep the same speakers? Replacing the neat little speakers won't go down well! So any recommendations in the £300 mark?
JimSpriggs is offline   Reply With Quote
Old 24-04-2007, 12:06 PM   #2 (permalink)
Re: Suggest replacement for JVC TH-A75R
Bump. Anyone know where I can get this repaired?
Old 24-04-2007, 12:25 PM   #3 (permalink)
Thanks: Gave 3, Got 22
I must admit I'm not a person who favours repair because often you end up paying £60-80 and the damn thing goes wrong again after 3 months. If you can't repair it yourself on the cheap I tend to think its better to change something.
If you really do want it repaired you should have local repair people available. Of course its knowing who is good and who isn't.
Basically though it seems with home cinema systems the dvd drive often starts playing up before the amp and speakers so if you go for a replacement maybe a amp and speakers package would be better with a seperate dvd player. Then it would be also easy to upgrade to hd-dvd or blue ray.
bonzobanana is offline   Reply With Quote
jvc, replacement, suggest, tha75r
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
