AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 14-04-2007, 8:25 AM   #1 (permalink)
yukichon's Avatar
Thanks: Gave 98, Got 68
Sony HT-DDW780
I know its only 5.1 but i bought this set-up the other day as its got everything i need , but when i set it up with the auto calibration its setting itself too low , i can put it up to max and its not even loud . I have connected it via optical to Sky HD and this has been my only sound test so far , do you think its because skyhd's output is low so therefore effecting the system volume ? I will be connecting it via optical to my PS3 later so ill see what the output is like then.
I did check the speaker levels which are set at -1 but i did use the auto callibration feature which ive read is the best method to get best results...any ideas or suggestions welcome..
My Media Room Project/Build
yukichon is offline   Reply With Quote
Old 14-04-2007, 5:13 PM   #2 (permalink)
yukichon's Avatar
Re: Sony HT-DDW780
I would also like to know what is the best setting for the surround and how to get DTS its all very confusing????
htddw780, sony
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
