AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 12-04-2007, 9:55 AM   #1 (permalink)
Talking Yet another newbie - Sky HD compatible All-in-one System
Ello Ello , yet another newbie here after some advice.
I have just purchased a new Panasonic TH-42PX70 and I'm looking for a new home cinema system to compliment it. Ideally I'd like a matching panasonic system as the viera connectivity would surely be a plus. I've been nerding it up a bit trying to get as much info as poss. In doing so, on one review I read a comment about there being only one panasonic system available that is compatible with Sky HD which I am also considering. Would any of you more informed members be able to shed some light and offer some sound advice (sound advice - get it). Thanks in advance.
jollybonehead is offline   Reply With Quote
Old 12-04-2007, 10:20 AM   #2 (permalink)
Thanks: Gave 4, Got 943
Re: Yet another newbie - Sky HD compatible All-in-one System
What is your budget?
Andy98765 is offline   Reply With Quote
Old 12-04-2007, 8:14 PM   #3 (permalink)
It wouldn't be massive. Something along the lines of £250 unless someone can totally convince me I need to invest a little bit more. Any thoughts?
Old 13-04-2007, 4:21 PM   #4 (permalink)
In the same situation, just got the same telly, and want to match up with a home cinema panasonic. At the moment, i'm not really impressed with the pana system out there. Think I'll pop in to there shop and ask for some input.
RstuDee2 is offline   Reply With Quote
Old 14-04-2007, 2:58 PM   #5 (permalink)
Thanks: Gave 3, Got 1
Why dont you try Sony HTSF100?
It has HDMI connections and it costs about300 pounds.
mariusz is offline   Reply With Quote
Old 18-04-2007, 11:20 AM   #6 (permalink)
Just been to the local pana shop. The assistant told me to hold off buying a system until May. This is when the new models will be out. Not sure if start or end of may.
Old 19-04-2007, 4:22 PM   #7 (permalink)
LG - LHRH760IA
Its the daddy, for the price, nothing comes anywhere near it.
Thats all.
RossH is offline   Reply With Quote
allinone, compatible, newbie, sky, system
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
