Decided to add my comments to this thread if someone is looking for HS X00 info. I purchased HS 500 and I'm very happy with the sound, especially the bass is excellent, the speakers sound very good on low and moderate volume, but give up a bit at higher volumes. This really is audible only when listening to demanding music and I'm really pushing the system.
Remote is pretty awful and works a bit slow. I also had an issue with the subwoofer auto on/off line, if I had that connected I got quite loud static on the subwoofer, fortunately the sub is clever enough to turn itself off when there is no input, therefore I just dropped the connector and now it works fine.
I haven't noticed any delay in the sound output, but I guess I'll try it out to see if the audio has the delay and I'm just too daft to notice
As a recap:
Pros:
- looks, it really is a good looking and relatively small system
- subwoofer, simply excellent
- overall sound, movies and music is good at least in my very subjective view.
Cons:
- remote, works slowly, complicated to program, modes are very messily designed.
- 1080i image looks pretty bad on my screen, however 720p is very good.
