AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-04-2007, 1:13 PM   #1 (permalink)
Connectivity on a Philips HTS3115
Hi all, first post on this forum so excuse be for being a bit ill informed.
I am about to invest in a complete new home cinema set up.
So far I like the look of this set up:
LG 50PC1D - 50" Plasma (I like the dual HDMI and PC inputs)
Philips HTS3115 - Upscaling DVD, home cinema in a box.
XBox 360, Sky+ HD.
My question is, what would be the best way to connect all this together?
From reading some threads on this forum it looks like there may be a problem with the Philips not having an optical audio input, for the Sky+.
I was thinking that I could get a HDMI switch and simply runn the XBox, PC and DVD through this to the screen. Will this work and will I get full surround from all sources?
Any help would be greatly appreciated.
BBoy69
BBoy69 is offline   Reply With Quote
Old 02-04-2007, 8:37 PM   #2 (permalink)
Re: Connectivity on a Philips HTS3115
You won't be able to run this all through the HTS3115 - not enough inputs.
Lovely system for basic bedroom or lounge setup, but has only got very basic input capability
If you're soending that much in general, mebbe look to spend a bit more on the DVD/decoder.
Think the Phillips site has a downloadable manual if you want to see the inputs.
Portland is offline   Reply With Quote
Old 04-04-2007, 3:09 PM   #3 (permalink)
Thanks for your reply Portland.
Do you have any suggestions as to wht DVD/Decoder I should look at?
Old 29-04-2007, 12:05 PM   #4 (permalink)
I've got the HTS 3115 attached to a Samsung 26" HDTV via HDMI. Problem is, I am looking into getting a HD disc player (not sure if Blu-ray or HDDVD) and realise that whilst I can view HD picture via HDMI, I can't output the sound to the HTS3115 without it being in stereo.
Does anyone know of an amplifier / receiver which accepts the speaker cables from the HTS3115 as they are those rectangle plug and play type?
If not, can someone offer me a suggestion??
Thanks.
theurbanline is offline   Reply With Quote
connectivity, hts3115, philips
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
