AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-04-2007, 11:43 AM   #1 (permalink)
Question Samsung HT-THQ22R/XEU Home Theatre & PS3
Hello,
I have bought a Samsung LE32R74BD HDTV and have connected it via HDMI to my PS3. The sound is quite weak though so I am thinking about buying this home theater:
Samsung HT-THQ22R/XEU Home Theatre Speaker Kit
However the PS3 has only 1 HDMI right? How do I connect it then to my TV and Home theater at the same time?
If I have to connect PS3 with HDMI to TV and a different way of connecting the PS3 to this Home Theater, which way would that be and would I need additional cables for that or are those provided by PS3 and Samsung HT-THQ22R/XEU Home Theatre enough?
Sorry I am a beginner in these things.
Many Thanks,
Houman
houmie is offline   Reply With Quote
Old 02-04-2007, 7:13 PM   #2 (permalink)
Acecross's Avatar
Thanks: Gave 1, Got 3
Re: Samsung HT-THQ22R/XEU Home Theatre & PS3
Not sure this is the best place for this question - might be better here.
To answer your question you should be able to use the HDMI to your display for Video and the Optical output from the PS3 to your Sound system.
By default the PS3 will want to output both Video and Audio via HDMI so you will have to change the settings in Sound settings options on the PS3.
Acecross is offline   Reply With Quote
Old 02-04-2007, 8:31 PM   #3 (permalink)
inzaman's Avatar
Thanks: Gave 61, Got 242
Moved to all in ones
Visit my Home Cinema here
inzaman is offline   Reply With Quote
home, htthq22r or xeu, ps3, samsung, theatre
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
