AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 08-06-2006, 9:49 PM   #1 (permalink)
arw
Posts: n/a
Denon S301 - Overheating???
Just taken delivery of Denon S301 at long last after ordering in January. Sound and picture quality are stunning.
However, after leaving the unit on for around 60 minutes I find that any CD / DVD that is removed from the unit is very hot to the touch.
Is this a normal characteristic for the S301 and other one box surround sound systems? I understood that all the amplification circuitry was built into the subwoofer box rather than in the main S301 unit, so I am a little puzzled as to what is causing all the heat build-up.
The unit has lots of ventilation, being on an open shelf with no other appliance nearby.
Any help/comments/advice would be appreciated...
Old 09-06-2006, 8:09 AM   #2 (permalink)
Thanks: Gave 0, Got 5
It's normal for it heat up like that.
It comes from having the internals of the 2900 which also heated up a lot. If the amp was in there as well, it would most likely melt.
So, no it's not a problem.
gareth_lewis2 is offline   Reply With Quote
denon, overheating, s301
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
