AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 19-02-2002, 3:27 PM   #1 (permalink)
ami
Posts: n/a
SONY DAV db Settings
whats the ideal db setting for a sony dav300 (got a FQ75 tv if that matters?), the room is about 16 feet long by 11 feet wide with the system in the top right corner, the speakers are set accordingly in each corner and have set the distance each speaker is in the DVD settings
at the moment it is set on default 0db, just wondering whether i would get better sound representation with another setting,
i have T2 and Phatom Menace on DVD and the sound is not dynamic as i expect (i use auto format decode when playing DTS or DD with the label appearing showing DTS or DD), (dont use any of the cinema or hall settings) apart from the sub woofer doing its thing when required
is it im expecting too much?
Old 19-02-2002, 6:06 PM   #2 (permalink)
Thanks: Gave 3, Got 14
Hi ami
My dad has the DAV system, i set the speaker values till i was happy with them (and him), its all a personal taste into the levels, and te layout of your room. Tinker until you like, just remember the centre speaker is locking the on screen dialogue so don't drown it out.
The auto format does not matter, and all the other 'virtual and hall' settings are just gimmicks in my opinion.
A little tip, whack up the speakers to full db level then adjust from there on, also dont forget (if you havn't already done so) to set your speaker distance from listenning positon.
"To me, my board" -Silver Surfer.
Harj is offline   Reply With Quote
dav, settings, sony
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
