AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-02-2006, 1:25 PM   #1 (permalink)
Thanks: Gave 5, Got 0
Which Kit for My Projector?
Have just purchased a Sharp Z200 Projector for my Home Cinema. I am now needing a 5.1 speaker system with DVD/AMP. The room is all pre-cabled.
I am willing to spend upto £400.
What do you suggest?
Thanks....Gary
garyhun is offline   Reply With Quote
Old 02-02-2006, 4:12 PM   #2 (permalink)
ash
ash's Avatar
Thanks: Gave 564, Got 401
Sony DAV700, can be got for £400 or so. It has optical, and coax in, and is a cracking DVD Player, andalso rear wireless speakers.
Batman Begins at IMAX!
ash is offline   Reply With Quote
Old 02-02-2006, 7:32 PM   #3 (permalink)
thanks ash
as a total newbie what are the optical and coax in's used for??? If this is dum and I should look this up elsewhere just tell me
Old 02-02-2006, 7:40 PM   #4 (permalink)
ash
ash's Avatar
Its so you can connect say DVD Players, Xbox360, Xbox, PS2, PS3 etc to it to get 5.1 sound.
If you plan to use the above, its worth getting. Also if you plan to buy a HD DVD or Blu Ray Player, it will be useful so you can get 5.1 sound from them.
Old 02-02-2006, 7:46 PM   #5 (permalink)
Many thanks. I will only have this sytem for about 12 months tops and it will stay in the house when I sell - I will spend more in the next property - so I guess the DAV500 will be adequate for now.
Old 06-02-2006, 5:09 PM   #6 (permalink)
Thanks: Gave 2, Got 12
no get the yamaha av57 and a good dvd player/recorder - much better sound if space allows!
Pretty small half a chicken yeah sure what i dont much
THERAAAVEN is offline   Reply With Quote
kit, projector
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
