AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 29-01-2006, 6:58 PM   #1 (permalink)
Thanks: Gave 31, Got 8
Sony Ht-k250 Home Theater System - Connection of DVD / VCR Combi Player
On behalf of my next door neighbour.
A Sony SLV-D950G DVD/VCR Combi is faulty and has to be replaced. She has substituted it with a equivanent Panasonic unit and asked me to install it for her. However I can't get any sound from the Sony HT-K250 Home Theatre system via Digital Coaxial lead connected to the SONY 'AUX' input. [The faulty Sony DVD had an 'Optical' DVD input which the Panny does not have].
Having studied the Sony HT instruction booklet I noted 2 statements viz:
1. "Settings for when you use Sony DVD player".....in the 'Connecting components with digital audio output jacks' section.
2. " You can select Sony components only" in the 'Listening to the Sound of Connected Components' section.
Does this mean I cannot connect up a Panny unit
Any advise / comments welcome
PROBLEM NOW SOLVED
jamct is offline   Reply With Quote
combi, connection, dvd, home, htk250, player, sony, system, theater, vcr
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
