AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 10-12-2005, 4:52 PM   #1 (permalink)
Thanks: Gave 21, Got 1
THR-3 rear speaker help please !!!
Hello just set up me THR-3 home cinema and i dont seem to be getting much noise out of the rear speakers seems very quiet, the front 2 are spot on could anyone please help me. I am a bit of a noob when it comes to setting up all this, I used the handclap to set it all up if that helps. !!!!!!
lasty82 is offline   Reply With Quote
Old 10-12-2005, 6:15 PM   #2 (permalink)
Thanks: Gave 2, Got 6
lasty82 - you can change the levels of the speakers using the set menu - it will be under audio and then levels. Have a quick look at the set up section in the JVC manual. There may also be a test routine there as well so that you can hear the effect of changing the speaker levels.
This works fine, I recently adjusted my rear speakers.
RR
robbierroy is offline   Reply With Quote
Old 10-12-2005, 9:20 PM   #3 (permalink)
RR
Thank you very much for that i will take a look, think i made a good purchase though the sound is great !
rear, speaker, thr3
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
