AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 09-12-2005, 6:29 PM   #1 (permalink)
cyclox
Posts: n/a
do quality cables make a differance ?
hi
i have got our system up & running ( yamaha av57 ) using the speaker cable that came with it & a cheap optical toslink + standard ariel lead to the dvd.
what i would like an opinion on, do good quality cables ( say £25 for a optical lead ) really make a differance as they say in hifi mags ?
Old 10-12-2005, 9:43 AM   #2 (permalink)
Thanks: Gave 9, Got 11
In most cases I have found an improvement when using better quality cables like speaker cables, stereo interconnects,digital coax,subwoofer cable.But recently I moved a piece of equipment and my 30 pound 1m Ixos optical cable was not long enough,so I replaced it with a cheap 2m optical cable bought on Ebay for a fiver with the intention of upgrading at a later date .TBH I could not tell the difference between the Ixos and the budget cable so will be sticking with the cheapo.
tv:sony KDF-E50A12U, DVD Player: Sony dvp-ns92 ,ps3, H.C. Amp: Sony STR-db790, Sky Box : panasonic, Freeview box : Sony VTX800, Speakers:Front : Eltax Liberty 5+, Centre : Eltax liberty, Rear : Eltax Bi-Polars, Subwoofer : Eltax Liberty,
pdbmjb is offline   Reply With Quote
Old 10-12-2005, 9:49 AM   #3 (permalink)
Thanks: Gave 69, Got 314
Optical cables carry digital signals - they either work or they don't. You won't see any improvement with more expensive cables. Spend your money where you will hear a difference - in the hardware.
Nick_UK is offline   Reply With Quote
Old 10-12-2005, 4:38 PM   #4 (permalink)
Smiffy 2's Avatar
Thanks: Gave 23, Got 52
I concur
Smiffy 2 is offline   Reply With Quote
cables, differance, make, quality
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
