AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 09-12-2005, 12:24 PM   #1 (permalink)
Thanks: Gave 17, Got 16
Denon DHT 500 problem
My DHT 500 has not been used for a couple of months and today when it is switched on comes up with a 'Protect' message on the machine and then switches itself off.
I thought that it might have a problem with the speaker connections but after unplugging all of them it still comes up with this error message
Its just over a year old and out of warranty.
Is there a quick solution?
Please help me before I go mad.
sofasurfer is offline   Reply With Quote
Old 10-12-2005, 4:37 PM   #2 (permalink)
Smiffy 2's Avatar
Thanks: Gave 23, Got 52
You haven't got the volume control cranked right up by mistake have you?
I used to own the DHT500 and the only time I ever saw the "protect" warning was when the sound level might have been getting to "annoying the neighbours" level.
It hasn't been cranked up by accident in the past year has it?
Smiffy 2 is offline   Reply With Quote
Old 10-12-2005, 10:06 PM   #3 (permalink)
No..volume is at minimum.
Machine switches off straight away after I press the on button
Old 11-12-2005, 12:30 AM   #4 (permalink)
Conn's Avatar
Thanks: Gave 41, Got 104
I had that. Ended up getting a new one under warranty (it was only 3 weeks old).
Conn is offline   Reply With Quote
Old 13-12-2005, 12:49 AM   #5 (permalink)
Thanks: Gave 7, Got 11
My Denon 500 is guaranteed for two years as standard. I would check your guarantee because you should be covered.
wicket is offline   Reply With Quote
Old 13-12-2005, 1:33 PM   #6 (permalink)
Thanks: Gave 16, Got 278
I thought all Denon equipment comes with a 2 yr warranty.
neilmcl is offline   Reply With Quote
Old 14-12-2005, 1:49 AM   #7 (permalink)
Conn's Avatar
It does. Why not give them a bell?
http://www.denon.co.uk/site/frames_m...ont&MID=5&ver=
Old 21-12-2005, 6:11 PM   #8 (permalink)
Thanks for that.
Didnt realise that Denon gear came with two years worth of guarantee.
Fantastic news.
500, denon, dht, problem
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
