AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 02-12-2005, 10:56 PM   #1 (permalink)
Thanks: Gave 54, Got 1
Switch Front and Rear speakers round
Hello,
Please forgive my stupidity, but when it comes to anything Audio I am how we say dumb,,,, And I have searched this site but cant find an answer.
I have just bought a JVC TH-S33. It comes with 2 tallboy speakers and 2 satelites. The tallboy have the short cable (To place at the front) and the small speakers have the long cable. Ideally I would like the tall speakers at the rear. Its not possible to remove the cable from the speaker. So:
1) Is it wise/ok to switch the speaker position (They are the same Watt and all
2) How would I do it as the cable is too short on the tall speakers.
Please help me learn..
vloothuis is offline   Reply With Quote
Old 03-12-2005, 1:34 AM   #2 (permalink)
shahedz's Avatar
Thanks: Gave 599, Got 354
if the wire has no specific connections at the end, you can just extend it, if it has got specific connections you would need to cut it to extend and then reconnect the connector . this may invalidate your warranty thought ( the cutting the connector option)
if they are the same wattage then it shouldnt be any problem. where you place them front or back , sometimes the front speakers have more drivers (actual speakers ) or can go to a higher wattage as they used most. but this may not be the case with you
Linn Kolektor pre amp & LK140 amp,Genki,Sony MD MDS JE510,Sonos ZP80 + CR100,Ariston RD-40 turntable,TDL RTL3 ,Samsung32R87, Yamaha YSP-1000,Panasonic PT-AX100E projector,Toshiba HD-E1 ,Sky HD, XBox 360, PS3,Harmony 885
shahedz is offline   Reply With Quote
Old 03-12-2005, 10:48 AM   #3 (permalink)
shahedz, Thanks very much for your reply, I appreciate it, at the end of the cables is just the bare wire to feed into the springy clip bit, Thanks for your input I greatly appreciate it.
Old 03-12-2005, 11:36 AM   #4 (permalink)
shahedz's Avatar
no problem at all mate
your lucky its the bare wire , you can get any normal speaker cable and literally just extend it then!
best of luck
Old 04-12-2005, 9:01 AM   #5 (permalink)
Black shrink tubing makes the job even more professional looking. Make sure the wires are properly crimpled/twistled together and then seal em up with some of that and a hair dryer!
techulous is offline   Reply With Quote
front, rear, round, speakers, switch
[IMG] code is Off
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Surround amp rear power amp front speakers zerovis Audio Processors and Power Amps 2 20-02-2005 9:21 PM
Upgrading rear and front speakers Hostile 17 Speakers 2 10-06-2004 12:13 PM
Switch solution to swap front and rear speakers? ms8qt Home Cinema DIY 6 17-07-2003 9:01 AM
Switch solution to swap front and rear speakers? ms8qt Speakers 4 14-07-2003 8:49 AM
AV ForumsOptimised for Firefox.
