AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 17-02-2005, 2:43 PM   #1 (permalink)
LG LH-C6235 power button fault!
My LG LH-C6235 as a power button fault, in that after a couple of minutes of being turned on it goes back to standbye. It is 14 months old and LG service want nothing to do with it as its out of warrenty!!!
As anyone else had this problem and how much did it cost to have it repaired, I could just be throwing good money after bad.
Thanks for any help.
tigerb is offline   Reply With Quote
Old 10-05-2006, 7:52 AM   #2 (permalink)
Fault
the fault is apparently caused by two 5v regulators IC 705 IC 706
I have one of these with the samre fault,I have just ordered the regulators to repair it,so will let you know if it works,have you had it repaired yet? if you know of a different fault email me paul.mortimer@boxclever.co.uk update :- replaced regulators cured the problem
mortimp is offline   Reply With Quote
button, fault, lhc6235, power
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
