Well I did not , but I guess this flaw is aslo in the original firmware.
This firmware is primary to watch your original dvd's
properly on your Progressive / VGA Projector / Mornitor,
In all avalble resolutions.
it you donk like it you can try the firmware for the kiss 470
Its V2.85 it has the same mods.
you can find it at http://194.109.4.5/470/470-ALLVGA+HDTV.zip
Jamo is a Kiss-470 OEM player so the Jamo firmware is identical to the kiss 470
except the logo's.
I received a CD from Jamo with the latest 2.9.4-firmware and when doing a "Full Update" everything works fine again
I guess the first update I did went bad.
Well as lang as you dont mind Macrovision or VGA limitation , the Jamo CD sould be sufficiant.
But I guess it could be a glits because I did not recive any other complains about this firmware.
Tried it.
Couldn't get the Jamo to boot from it.
Turned player off, then on, it just thought it was a normal disc.
It you try and play the dvd it says its a boot disc, but won't boot from it!
Downloaded it twice and used 2 different cd's!
