AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 15-02-2005, 7:03 PM   #1 (permalink)
weavib
Posts: n/a
HELP Denon 500sd firmware update error
i really need some help please!
I installed the firmware upgrade that sasquatch had a link to, and confirm that it worked perfectly on my denon. All was going well...
However, my problem started when i left the disk near the player, a stupid mistake!! the disc ended up being put back into the denon - and when the missus didn't know what was happening switched the power off,
during the update!
I fear the firmware has been wiped. The disk is still in the tray - wont eject. Only message is MECHA ERR on the display. nothing displays on the tv. all buttons do nothin when on dvd function
Anyone with any ideas what i can do?? Is there anyway to perform a reset?
All help greatly appreciated
Old 15-02-2005, 7:18 PM   #2 (permalink)
Thanks: Gave 0, Got 3
The only thing I could suggest is to un-plug the unit for at least twenty four hours as I believe this resets the system - although as the firmware was being updated I'm not sure what state the system will reset too? Worth a try though.
Hope it works out.
Nathan
nathanhill69 is offline   Reply With Quote
Old 15-02-2005, 7:28 PM   #3 (permalink)
Conn's Avatar
Thanks: Gave 41, Got 104
Weavib - pm
Conn is offline   Reply With Quote
Old 15-02-2005, 8:11 PM   #4 (permalink)
weavib
Posts: n/a
have try unplugging the unit... not looking too hopeful..is it??
Old 15-02-2005, 9:55 PM   #5 (permalink)
Sounds like an e-mail to Denon then to say "Oooops, what shall I do?". I've always got a really fast response using this e-mail address (usually within hours):
denon.consumer.support@denon.co.uk
Nathan
Old 15-02-2005, 11:13 PM   #6 (permalink)
during the update!
Women + technology = plenty of time tryin' to sort the mess out! I can't even remember the number of phone calls I've had from my missus that included the line "I don't know what happened, but it just stopped working...."
Ps. Sorry I can't offer any advice on the reset
Judders is offline   Reply With Quote
Old 16-02-2005, 8:09 AM   #7 (permalink)
weavib
Posts: n/a
Thanks nathan for the email address & your help- probably my best option.
judders - it was about the first time she has even used the denon!! Think she will be too scared to do anyhing in the future
worst thing though it was MY fault for not putting the disk away somewhere safe
nothing worse than breaking your favourite toy...
Old 18-03-2005, 6:42 PM   #8 (permalink)
Thanks: Gave 8, Got 2
I've just been setting my 500SD up now... running through Lord of the Rings for a test and when I tried to eject after I got a lot of whirring and the same message 'Mech Err' .... aaaarrgghh
Any update on this? What did you end up doing? For info, the machine had been multiregioned by the retailer and had worked out of the box... albeit briefly!
lol... now sorted. Unplugged for 15 minutes, plugged back in and now OK. A bit worrying tho
Wurzel is offline   Reply With Quote
Old 18-03-2005, 8:14 PM   #9 (permalink)
Conn's Avatar
Bit of luck. Left mine unplugged for 3 days with no change and ended up getting it replaced
Old 18-03-2005, 8:22 PM   #10 (permalink)
Hmmm... thats a bit worrying really - if its done it once...
I'm glad I bought from Peter Tyson now as their return policy is less hassle than some others that were a similar price
500sd, denon, error, firmware, update
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
