AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 12-02-2005, 4:36 PM   #1 (permalink)
Thanks: Gave 2, Got 10
DHT500 Help please
hi Guys,
Apologies for another similar post, but I really could do some help here.
I am trying to connect up my Denon DHT500.
I want to connect my Sky+ to it via RGB scart and then connect the Denon to my TV (Phillips pf9986 LCD) via Component/DVI.
So far, when everything's connect, I get a "picture format is not available" message on the screen.
I've checked the settings on the Denon, picture format is widescreen, tv type = tried all of them etc etc.
Can someone advise as to what I need to do to get it working.
n.b. DVD via component to the TV works, but only when using Progressive Scan, but I get black bars at the top and bottom, DVD via scart to the TV is fine,
thanks in advance
Lee
lee_d_m is online now   Reply With Quote
Old 13-02-2005, 4:48 PM   #2 (permalink)
The DHT 500 will not convert anything to component video. It only does composite video switching. The scart socket is not a video input (though it will accept audio input). You will only get a signal from the component out when playing a dvd.
If you want video switching through the dht500, connect your sky box to the dht500 with a composite video cable and connect the scart to the tv. You can connect the component leads in parralel to get the component video for dvd. The DHT-500 does not have a dvi out. If you need component video switching/conversion get a more expensive receiver.
Hope this helps.
drbob is offline   Reply With Quote
dht500
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
