AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 09-02-2005, 9:23 PM   #1 (permalink)
any advice
in the process of buying a new dlp tv, i need a new dvd player with hdmi connection, if possible multi region . is there a set up out there that is a all in one system (theatre system ) or bought as seperates. roughly have about £500 to spend.
skip is offline   Reply With Quote
Old 09-02-2005, 9:34 PM   #2 (permalink)
Assured Advertiser
hornydragon's Avatar
Thanks: Gave 76, Got 1,109
Apart from Samsung 945? a DVi/HDMI player will eat almost all of your budget....Panny S97 is £300....others are £500+
(WHY HDMI DVD player?????)
all in ones arent that great unlesss you spend seperates money then might as well get seperates.......
hornydragon is offline   Reply With Quote
Old 09-02-2005, 9:49 PM   #3 (permalink)
thanks for that, no special need tv also can be connected via component but has hdmi , and from what i have seen that seems to be the better connection. or do you disagree. ive seen some threads about denon set ups would you advise one of these sets using component.
Old 09-02-2005, 9:54 PM   #4 (permalink)
Assured Advertiser
I think a good analogue component output looks better than DVi/HDMI for DVD mate
Get a good component player an AMP and speakers, (need to increase budget a bit tho)
advice
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
