AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Home Entertainment Players and Recorders > All-in-one Systems
LinkBack Thread Tools Display Modes
Old 04-02-2005, 12:00 PM   #1 (permalink)
500SD doubt
Please,
I've a Denon 500SD and I do not know if it is possible to see the total and remaining time when dvd is playing.
Thanks for your help.
(V. Argudo)
amundsana is offline   Reply With Quote
Old 04-02-2005, 5:01 PM   #2 (permalink)
Conn's Avatar
Thanks: Gave 41, Got 104
Not that I could see when I played around with the remote
Conn is offline   Reply With Quote
Old 04-02-2005, 10:08 PM   #3 (permalink)
MStarkey's Avatar
Thanks: Gave 47, Got 26
Press the 'Display' button repeatedly during play mode.
regards,
MStarkey is offline   Reply With Quote
Old 04-02-2005, 10:40 PM   #4 (permalink)
Conn's Avatar
That gives expired time, but not total or remaining?
Old 04-02-2005, 10:50 PM   #5 (permalink)
MStarkey's Avatar
Hmmm, maybe not then - sorry.
Old 07-02-2005, 8:08 AM   #6 (permalink)
Unhappy
Thanks for your commentaries, I'm very sorry, really those are very useful functions.
A zero for Denon.
bye.
Old 15-06-2005, 11:51 PM   #7 (permalink)
pitijopo
Posts: n/a
Hi. I have just bought the Denon DHT-500SD Home Theatre System. I have connected it using a scart cable and the DVD is superb. Unfortunately I can not manage to get the TV (Sony Freewiew digital TV) sound through the theatre system. What shall I do? Thank you in advance for any help you may provide.
M
Old 16-06-2005, 9:41 AM   #8 (permalink)
Thanks: Gave 0, Got 3
Hi Pitijopo
Just a friendly word of advice, it's regarded as bad form to ask the same question on multiple threads, you only need to ask the question once on an existing thread OR start a new thread and someone is bound to spot your question.
If you're connected via the SCART then set the function on the Denon to TV, this should pull the sound of whatever you're watching on the TV down the SCART and through your amp. Alternatively, if your TV has L & R phono outs then you could connect these to AV 1 or 2 on the back of the Denon, ensuring you set the relevant AV inputs to analogue, using the remote (Each AV channels input can be switched between digital, analogue etc.)
Hope this helps
Nathan
nathanhill69 is offline   Reply With Quote
500sd, doubt
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
