Samsung HDTV + Samsung receiver and Anynet issues/annoyances
| Post Reply |
| | #31 |
| New Member |
Hello Broadz, Well you hit the nail right on the head there.... I have owned several A/V stereo systems in the past, jvc, onkyo. After going through them all and being mostly pleased with them. They all function as I would expect the samsung home theater to function. But, now I have gone through a good period of living without a stereo, due to life circumstances. So, I have come back to buying again and was thinking to myself...Hey, now they have a new concept of "home theater system." The sound is ok, not the best, of course, but it fits my needs now and I dont have to drop a lot of dough..So I will go for it. Well as I see now as you clearly pointed out, I should have dropped the cash and bought a A/V Stereo system, then I would have got what I wanted...Thanks |
| Quote |
| Advert Log in or sign up to remove |
| | #32 |
| Member |
I've got exactly the same issue, but with the Samsung HT-D6750W Home Theater package. I can see both sides of the argument to be honest, but am in the camp of wanting the amp and TV to switch on together. That's why I bought the amp after - to maximise the sound quality. Has this ever been resolved? I've updated both TV and amp and I guess it hasn't been? Thanks |
| Quote |
| | #33 |
| Member | This may help . . .
oscahie . . . In case you've not discovered this for yourself . . . . If you would like to see a numeric value for your sound setting, the following method works if you want. When playing a source through the amp, toggle the mute button on the TV remote. When taking the TV off mute a numerical value is shown in the Anynet+ display/logo. If you use the amp/BD player remote to control both devices make sure it's set for TV operation. If it's in BD mode you won't see anything. Not convenient, but a work around if you want it. As regards the issue whereby when the TV is taken out of standby and doesn't bring on the amp, I'm in the same came as you. I can see both arguments, but I'd wager the vast majority of people using this forum will be the same. The idea of making a sound system purchase is to maximise sound quality from all sources at all times. As great as these ultra thin screens are, they also give ultra thin sound . . . Regards Dumfy |
| Quote |
| | #34 | |
| New Member | Quote:
A suggestion to Samsung - the HTS is an exceptional Anynet+ device in this context as you MAY indeed (I do) want it to come on automatically when the TV is switched on, without firstly having to select it as the source via the TV - so why not provide an user option in the Settings menu of either the TV or HTS that allows this? | |
| Quote |
| | #35 |
| New Member | Completely and utterly incorrect. I DO want this feature - as do probably the very large number of people who buy Home Theatre Systems primarily to extend the audio capabilities of the TV - not as a standalone Blu Ray player which happens to have great sound.
| Quote |
| | #36 | |
| New Member | Quote:
You're definitely not alone mate. Did you have any joy speaking with Samsung? I'm just sorry I'm hitting this forum so long after the original posts. | |
| Quote |
| | #37 | |
| New Member | Is this guy for real? Quote:
| Quote |
| Public Notice of Infraction for the Previous Post Issued: 08-11-2012 at 5:00 PM |
| Creating a particularly trite and unhelpful post likely to annoy |
| | #38 |
| Moderator |
@ honeyridges, As a new member, I would advise you read the forum rules, as you should have, as indicated when you joined, and as such, DO NOT insult other forum members, in such an childish manner.
| Quote |
| | #39 |
| Member |
Hi there, I am too a long-suffering user of a Samsung (LE32D550) TV along with a Sony HT-thing. I totally agree with the OP and many others, it seems there are many people who want to use the external speakers supplied with a "Home Cinema" or "Home Theatre" kit for all the sound their TV outputs, not just for a DVD or BD, and I think it's a totally valid desire. I consider the item to be a receiver/amplifier with a built in optical disc, not the other way around. I might be wrong in that respect, but I bought it for the speakers not the optical drive. Unfortunately there really is no way to make the television instruct the receiver to come on automatically. (It will, perversely, turn it off automatically). It would indeed have been very easy for Samsung to implement this, and in fact many Sony and Panasonic televisions do have this option. In a sense we unfortunately "got what we paid for" (making the assumption that everyone elses Sammy TV was indeed cheaper than a "posh" Sony or Panny). I find the best half-solution is to hit manually hit the HT power on button before I plonk my fat arse down on the sofa. Turning on the tele, the receiver is good to go. The TV also seems to have less trouble recognising it, and the volume control through HDMI works (almost) straight away - I found that turning the HT on afterwards, the TV would sometimes not communicate with it and not connect the volume control system. I do see a "HUD" as you put it (I understood you), and it has a %age volume displayed numerically (no slider). This might be TV model specific. I'm not sure why Broadz was being so (seemingly intentionally) obtuse in refusing to accept that you had a reasonable claim to be miffed at your television. Some of us don't have several hundred quid to spunk on an Onkyo* and a set of Missions* (unfortunately) and just want something that does the job (or, in this case, not). But "what a plonker" was a bit out of place lol. * just for examples sake, not an avocation of any preference. If your TV is fancy enough you could try and decipher to "samyGo" website as they might have some magical hacked firmware. But the site is so ramshackle and awful, buying a new television (or the "pro" speaker setup) might be preferable ;D . edit: or you could get a Harmony remote control and set it to turn both things on at once (turn off CEC/Anynet+) Last edited by mrpl0w; 16-11-2012 at 10:29 AM. |
| Quote |
| | #40 |
| New Member |
I agree with those who want their receiver coming on at the same time as their tv. I have a Sony ht with hdmi pass through and a freeview+ box passing through my amp. The tv turns on the freeview box, but doesn't turn on my amp as its passing through. Most annoying to have to turn on the receiver by going to tools, anynet, receiver, on. But if I turn the receiver on before the tv then the tv plays sound through both its own speakers and the amp making an ever so slight echo. So I can't even use that as a workaround. Still have to go to tools every time.
| Quote |
| | #41 | |
| Member | Quote:
(Really I did it because my doddering parents-in-law are quite often 'round, and there's just no point trying to explain what to do...) | |
| Quote |
| | #42 | |
| New Member | Quote:
![]() Think that's gonna have to be my solution for the foreseeable future. People seem to have success with onkyo receivers, so maybe I'm due for an upgrade... Any excuse | |
| Quote |
| | #43 |
| Member |
Haha, they understand there is a magic box that the young 'uns use to make sound come from all directions. We leave it at that. The whole hdmi control malarkey seems very 'un-standard', so I guess Onkyo decided that turning on the receiver IS a good idea and put that in their interpretation of it. It probably really annoys a load of Onkyo users, and they're on their forum shouting about the stupidity of it |
| Quote |
| | #44 | |
| New Member | Quote:
| Quote |
| | #45 | |
| Member | Quote:
They might not even do so, but hell if it lets me buy a new tele ![]() Anyway I'm not sure if I made it clear, but I also have a Sony HT and a Samsung TV. I keep the Sony HT remote lying around. If you press "TV" on the HT remote, the receiver turns on in TV mode. When you turn the TV on it seems to instantly link the 'anynet+' bs, and the volume remote straight away links to the sony. No need for "tools, anynet, receiver on". | |
| Quote |
| | #46 |
| Limited Member |
Hey, I didn't know this thread was still alive, I'm not getting email notifications for some reason. Anyway, I'm obviously very disappointed as 1 year later there is no fix whatsoever. My workaround, as mentioned before, is to simply leave the HTS turned on 24/7, which is less than ideal, but yeah... what the hell. For the sake of it I just sent a new complaint email to Samsung, to which I expect no response, but at least I released some frustration that I had just dusted off after re-reading the thread. @Dumfy I was aware of the "mute/unmute to see the current volume level" trick, but thanks for pointing it out. This is just another annoyance by Samsung that I've learnt to live with... @honeyridges no luck at all, unfortunately. I just visited this thread thanks to an email notification for a similar thread at cnet (Can a TV use Anynet+ to automatically power on a receiver? - CNET Samsung Forums). It's good to know that I'm not alone on this 'campaign' to make Samsung come to its senses though! Last edited by oscahie; 11-12-2012 at 2:12 PM. |
| Quote |
| | #47 |
| Member | annoyed at this issue too..
I am another who is frustrated at the stupid shortcomings on the Samsung TVs, I have a d7000 and an AV separates system and now a Logitech harmony remote to try and get round the dumb design and I still cant get it to do what I want which is not unreasonable.. their tech support is just useless as well, I have given up with them.. I can use my logitech to turn on the TV and my AMP and my Sky box, but after 10 seconds of allowing me to watch Sky on the amps cable input, for some stupid reason, the TV forces my AMP to the TV input rather than the Cable one I use for the Sky box (it is the TV as it has happened with the last 2 av receivers I have had of different brands). The only way to suppress this is to turn off the ARC settings and thus Anynet but then when I want to use the Smart Hub or watch freeview ARC is off and doesnt work and thus no sound goes to the amp unless I go through the menus to turn on ARC again.. aaarrgh! Also everytime I turn my TV off it seems to wipe out the Anynet settings that connect it to the receiever, so even if I do want use the Smart Hub I have to go and turn receiver on again through the menus.. Even the harmony remote cant help here as the menu navi is too hard to programme on the samsung telly. Has anyone got any suggestions on how I can solve this short of buying a new telly? |
| Quote |
| | #48 |
| Member |
The only way I've found to stop my amp from turning to TV mode is to delete that source in the amp menu. Like you say not much use if you want to use the smart hub. It would be nice if Samsung sorted this out!! |
| Quote |
| | #49 | |
| Member | Quote:
If I then need a screen in order to watch my Home Theatre DVDs then surely I would want the speakers to turn off once I had finished viewing the DVD. I have an Onkyo HTX22HDX Home Theatre System, this doesn't come with a DVD player but will turn off with my TV. It will not turn off when I exit my SkySat or my external DVD player. Is this not the way that a home theatre system should work? Come on Samsung get with the game!!! | |
| Quote |
| | #50 |
| New Member |
My parents have a new 6100 series Samsung TV which is connected to an HDMI-CEC compliant blue-ray player and speaker system through HDMI-CEC and ARC. Their Samsung TV seems to suffer from this same problem/oversight/design flaw/lack of configuration/misunderstanding of how speakers are used. I discovered the Tools->Anyconnect+->Receiver->On solution that was posted earlier in this thread and so far, that seems to be the best I can do. Could someone confirm the following: (i) It is impossible to have the amplifier and speakers turn-on when the TV turns on. (ii) Samsung does not have any intention of fixing this problem. (iii) Connecting to the amplifier with S/PDIF instead of HDMI-CEC and ARC will not fix this problem. It's too bad Samsung seems so intransigently out of touch with the way their products are actually used. I was thinking of buying this same TV since the picture, case and size are quite good. Now I'm going to keep looking for something that plays well with others. (iv) I've got to believe that Samsung is the only one who has this issue. Is that true? It's clear from this discussion that there needs to be an option which satisfies the "I want my tele on/off to control my tele and nothing else thank you" crowd as well as the larger "I'd like my tv based entertainment system to come up to a usable configuration with one button, especially if my tele speakers are marginal". How hard can that be? |
| Quote |
| | #51 |
| New Member |
hi I share the same problem. With other usere regarding using my new 64" tv and samsung ht3730 purchased in dec21012 I bought the ht system to be able to use my souround speakers to watch my tv / foxtel. Regardless of what anyone think how it should work, samsung anynet claims that it will alow you to control everything with one remote;, including turn on/off change channels etc. IT DOESNT DO THAT AT ALL. In my opinioin its mis leading. Samsung will refund my home theater but i also demand samsung to change the advertising of anynet as its misleading and untrue. I used panosonic vera link and it worked great. Just moved to a new house and purshaed new tv and ht but soon found out that anynet is actually USLESSNET I SPENT 3.5 HOURS TODAY AND 2HOURS ON 3 OTHER OCCASSIONS WITH SAMSUNG! SPOKE TO DIFFERENT CUSTOMER SERVICE OFFICER INCLUDING SUPERVISORS AND AT THE END THEY AGREED TO REFUND THE HT UNIT. it took me 6 buttons to get my tv playing through my ht speakers. My conclousion, anynet is uslessnet |
| Quote |
| | #52 |
| New Member |
Pclinkpro, I agree with your sentiment, especially when it comes to false advertisement and the amount of wasted time this deficiency caused both of us, but I wanted to clarify one detail. The problem with the Samsung devices is not Anynet, but their refusal to implement one simple option on top of it. Anynet is just Samsung-speak for HDMI-CEC, which is a standardized means of passing commands over HDMI between devices. If your setup is like my parents, the Samsung TV is perfectly capable of sending the "turn-on" command and the receiver is perfectly capable of responding. What you and I would both like and what every other vendor has implemented is an option for the TV to send the "turn-on" command to the receiver/amplifier each time the TV is turned on. This has nothing to do with the communication mechanism, but with the TV itself being deficient. The fault is with Samsung, not the HDMI-CEC standard. For example, if you bought a Panasonic or LG TV and connected it to your Samsung receiver and enabled this option in the TV, at least in theory, you could get what you want even though the receiver would be branded Anynet. Similarly, a Samsung TV connected to a Panasonic receiver (my parent's setup) would fail. |
| Quote |
| | #53 |
| New Member |
I purchased a Samsung 8000 series TV and a Samsung Home Theater System to go with it. I too would like to use the HT sound for everything and am very frustrated by the implementation making this very difficult.
| Quote |
| | #54 |
| Member |
Hi, I would not want my TV to turn off just because I turned off my Home Cinema, and I wouldn't want the Home Cinema to turn on when I turned on the TV, that would really annoy me and be a deal breaker. Thus, for me, my Home Cinema works the way I want it to.... Chris |
| Quote |
| Post Reply |
LinkBack URL
About LinkBacks
