Not an expert on audio but on mine
I use the ARC (audio return channel) that way you use cheeper short cables from your bits and bobs to the amp and 1 long cable to the ARC on the tv normal hdmi sockets only allow one direction --the arc sockets allows the audio to go both directions thats how i get the normal tv sound to my 5.1 speakers for a better sound than the tvs speakers. And remember it will only be 5.1 if the broard cast is 5.1
I'd have to use the SR906 remote to select source I guess and always have the SR906 on..? Then again I guess it's Simplink compatible..... |
I can not get the simplink to work if i have the tv on and start a movie, the movie plays and the sound seems to be simplink but not the vision. I then have to select the source on the tv remote and then play the movie from the start again.
Yes with the arc option the receiver needs to be on - you will not be able to watch a movie or play a game without it on (but why would you want to not have 5.1)
It does not have some kind of passive pass through - it has to be powered. But if you are useing your cable box and it is not broadcasting in 5.1 then I suppose it is not worth it as you say your receiver will also need to be on too just to get any sound
In your case you could do both - have the dvd player use the arc as that is always a 5.1 source. And have your cable box direct to the tv with an optical to the receiver for when there is somthing on that is in 5.1
On the other hand if you have young kids and they want to watch somthing it will be a faf as the receiver will need to be on and im sure they would of been happy with just the tvs speakers for ben10 or whatever
