Hi Nobby,
Thank you for your reply - I appreciate it and I think I understand the points you made.
I am thinking abouy adding the
Panasonic DMR-EX769EB-K to the mix. It is a 160GB HDD and DVD recorder with Freeview+.
Can you or anyone confirm my understanding of how these would be linked:
I imagine that the coax cable would first connect to the Panasonic HHD and DVD recorder and another coax cable from this machine into the arial in socket of the TV.
This means the Panasonic can record TV channels and the Toshiba telly will also get the channels for viewing.
The Samsung home cinema wouldn't need any coax cable in or out of it because it is only being used to play DVD's.
I don't know where all the HDMI cables go - from where to where - to get the surround sound from both the Samsung home cinema and the Panasonic recorder.
With this set up I have a home cinema surround system coupled up to something that can record programs. Also if I should ever want to what VHS tapes I think I could just link the VHS player via SCART.
I know there's a lot to take in but if anyone could advise on my though process I'd appreciate it.
