Samsung 3Dtv with Onkyo TX-SR608 HDMI issue
Old 13-06-2010, 4:57 PM   #1
NE0 NE0 is offline
NE0's Avatar
1,504, Level: 8
Points: 1,504, Level: 8 Points: 1,504, Level: 8 Points: 1,504, Level: 8
Thanks: Gave 1, Got 2
Samsung 3Dtv with Onkyo TX-SR608 HDMI issue-FIXED
There appears to be a problem with Samsungs 3d TVs with the latest AV Receiver ONKYO TX SR608.
I've reported my issue to Samsung via their online support, they sent an engineer after a factory reset and install of the latest firmware 1013 did not solve the problem.
This same problem has been mentioned in other threads but unless you look at them (the title might not be your TV) you may not find them.
http://www.avforums.com/forums/3d-lc...dmi-issue.html
http://www.avforums.com/forums/3d-lc...rs-thread.html
With other forum members mentioning this and the Samsung engineer who came out to 'fix' mine stated he'd seen the same problem with the same two products at the beginning of this week. i thought I'd create a common thread highlighting the issue.
The problem is with the HDMI handshaking between the two units.
Initially everything is fine until you turn off the AV Receiver followed by putting the TV into standby.
Once the SR608 is turned off it's not recognised by the TV the 2nd time around when you turn the TV back on followed by the 608.
In my case the Onkyo is connected to HDMI port2 and after you turn it off. (TV into standby) turn on the TV, then the SR608 is not recognised and HDMI slot3 appears in the top source menu even though nothings connected.
The TV then looks for the connection and then states no cable connected.
The workaround, as found by others, is to simply switch off the TV, unplug from the wall, then turn it all back on again. Everything is fixed.
It would appear that if you do not turn off the SR608 and only have it in standby mode, the TV does not have a problem with it. Its only when you switch off the AV receiver does the problem manifest itself.
Mines a UE40C8000, The samsung engineer said the other this week was a UE46C8000.
Spursman1 has the same issue with his UE46C7000 and the 608 along with Max7 who has reported the problem in a thread about his UE55 and the 608. Antlane mentions he has the same problem with his 46c7000 but doesn't mention the 608.
The engineer is reporting it to headquaters and hopefully a firmware update will come out of this.
NE0
Old 14-06-2010, 1:04 PM   #2
1,012, Level: 7
Points: 1,012, Level: 7 Points: 1,012, Level: 7 Points: 1,012, Level: 7
i have experienced the same thing with my ue46c7000 and onkyo 608.
seems to be ok if i turn the amp on first then the tv.
Old 16-06-2010, 9:37 AM   #3
882, Level: 6
Points: 882, Level: 6 Points: 882, Level: 6 Points: 882, Level: 6
Same problems samsung 46c7700 onkyo 608 and bdc6900.
When i first put the onkyo on everything is working fine.
Old 16-06-2010, 1:02 PM   #4
2,639, Level: 11
Points: 2,639, Level: 11 Points: 2,639, Level: 11 Points: 2,639, Level: 11
Thanks: Gave 1, Got 3
I have the same issue with 46c750 and onkyo tx-sr876. Unplug the tv works for me.
Old 16-06-2010, 5:09 PM   #5
2,149, Level: 10
Points: 2,149, Level: 10 Points: 2,149, Level: 10 Points: 2,149, Level: 10
Thanks: Gave 0, Got 4
Interesting as i've got a 608 and 55C8000 in boxes ready to be connected. Seems very odd its only these particular models. I suppose if I used my Harmony 1000 remote could I not configure it to switch the amp on first?
Old 17-06-2010, 7:08 AM   #6
635, Level: 5
Points: 635, Level: 5 Points: 635, Level: 5 Points: 635, Level: 5
Thanks: Gave 1, Got 4
Just got the 55C8000, as I have the 607 that I am using to switch any HDMI 1.3 based sources and it's doing exactly the same thing.
Old 17-06-2010, 7:56 AM   #7
2,149, Level: 10
Fingers crossed Samsung come up with something fast!
Slightly off topic but fairly new to HDMI, what type / version HDMi cable should I be using to connect my amp to the TV? Do I need one of these new 1.4 or does it matter?!
Chris
Old 19-06-2010, 9:16 AM   #8
1,634, Level: 9
Points: 1,634, Level: 9 Points: 1,634, Level: 9 Points: 1,634, Level: 9
Thanks: Gave 3, Got 0
Just wondering if this issue is with the Onkyo 608 receiver rather than the Samsung TV? I hope not since only the Samsung TV allows user upgradeable firmware. I trust connecting the bluray directly to the TV works fine? Has anyone else tried a different brand of 3D Bluray player and do they experience the same HDMI handshake issues?
Old 19-06-2010, 2:21 PM   #9
635, Level: 5
As posted, my 607 has this, while the Sony BD-S470 I have connected directly to another HDMI port has no issues whatsoever.
Old 19-06-2010, 3:06 PM   #10
thfccambs's Avatar
32,027, Level: 43
Points: 32,027, Level: 43 Points: 32,027, Level: 43 Points: 32,027, Level: 43
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 540, Got 1,109
Was looking at buying the 63" Samsung, think i'll hold of at the moment.
Old 19-06-2010, 6:59 PM   #11
1,634, Level: 9
ok, so does this indicate it's the Samsung bluray drive being the issue rather than the Samsung TV itself? I have a 608 and just about to order a 55C8000, so want to be sure. I thought the handshake issue is between the Samsung TV and 608. Sounds like a handshake issue with the Samsung Bluray to the TV via the 608.
Old 19-06-2010, 7:27 PM   #12
872, Level: 6
Points: 872, Level: 6 Points: 872, Level: 6 Points: 872, Level: 6
I have a samsung ue46c7000 tv and a Sony RHT-G11 surroung sound(hdmi 1.4) and im
having the same problems.Sometimes the TV doesnt seem to find the connection and i
have to turn every thing off and start it up again.So i dont think its a samsung blueray
issue.
Old 19-06-2010, 10:53 PM   #13
1,634, Level: 9
Wow, so the issue is not confined to the Onkyo receiver, that's actually worse. I really hope Samsung come up with an updated firmware fast. Most people are buying their TVs with for 3D which requires a 1.4 HDMI connection. This would be considered a pretty big issue in my book!
Old 20-06-2010, 9:20 AM   #14
paulr2006's Avatar
17,191, Level: 31
Points: 17,191, Level: 31 Points: 17,191, Level: 31 Points: 17,191, Level: 31
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 953, Got 1,548
For what it's worth it's not just confined to Samsung, the 1.4 out of the Panny player to the TV work fine but the additional 1.3 HDMI out to my Onkyo 875 is very difficult to get synced! so great picture & sound about 3 times out of 5 attempts!
Old 20-06-2010, 11:27 AM   #15
3,474, Level: 13
Points: 3,474, Level: 13 Points: 3,474, Level: 13 Points: 3,474, Level: 13
Thanks: Gave 3, Got 3
I've had a handshake problem with my current set up (listed below), if I switch on everything in a specific order then all is ok. For my set up I have to switch on my receiver first followed by the source I'm using, then my screen last.
Thought it might be worth a try
Old 22-06-2010, 9:00 AM   #16
10,503, Level: 24
Points: 10,503, Level: 24 Points: 10,503, Level: 24 Points: 10,503, Level: 24
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 63, Got 225
I have an onkyo 705 and happily run my xbox 360 and ps3 through the amp to the tv without any issues - however when playing a 3d source on my ps3 i do have a problem as my tv loses the pairing with my amp.
I basically have to switch a HDMi lead when playing ps3 3D games - ie plug the ps3 straight into the TV
Old 22-06-2010, 9:21 PM   #17
thfccambs's Avatar
32,027, Level: 43
Activity: 3.8%
Any update about this issue?
Old 22-06-2010, 11:59 PM   #18
885, Level: 6
Points: 885, Level: 6 Points: 885, Level: 6 Points: 885, Level: 6
Exactly the same issue happened to me with Samsung UA55C7000 and Onkyo TX-SR578. HDMI plugged in to HDMI 2 for ARC on Samsung. All worked fine on setup, then next morning turn the TV on, it doesn't recognise the amp, and it has HDMI3 highlighted in the source (no connection though), and HDMI2 is gone from the list.
Disabling the Anynet+ Auto-On/Off and turning on the amp before the TV has fixed the problem.
Old 24-06-2010, 8:58 AM   #19
880, Level: 6
Points: 880, Level: 6 Points: 880, Level: 6 Points: 880, Level: 6
Samsung 3D with Onkyo TX-SR308
Again i am having same problems as the other people. TV does not recognise the amp and it does work sometimes when you turn on amp, sky then the tv. However even this is not working each time. Have contacted Samsung and they are sending an engineer round. The other disturbing thing is that when i gave Samsung the serial number they had no record of it. That really is scarey. Will let you know how i get on with the engineer.
Old 24-06-2010, 2:00 PM   #20
NE0 NE0 is offline
NE0's Avatar
1,504, Level: 8
Well, its nice to know that a lot of others are experiencing the same issue, and its not just isolated to my set!
Same thing happened with me! my number is not recognised! they contacted me to resend it, so I did, still not recognised, they now want proof of purchase as they still do not recognise the number! So I sent them a photo of the back of the set with the number and I also invited them to phone me so i could READ out the number to them!! But they want the proof of purchase from Sevenoaks hi Fi where I purchased it. Maybe i've been sold a fake? I've said if its a fake they are more than welcome to take it away and check it with all the packaging, they really do p*** you off sometimes!! Could it be their software has the problem?
I contacted the supplier of my Onkyo and they forwarded the issue to Onkyo. Not sure if Onkyo can resolve it as the 608 doesn't seem to have an upgradeable firmware. However, they might liase with samsung I suppose.
So far nothings appeared on the Samsung website as regards to a fix, I assume the engineer filed his report, so we wait and see, afterall its only been a week or so since it was highlighted, I guess it takes time.
Having said that its also quite unlikely they are monitoring this thread so they may well be blissfully unaware of the issue
I suggest if any engineer looks at your set, you also refer them to this thread!
NE0
Old 25-06-2010, 12:50 PM   #21
2,173, Level: 10
Points: 2,173, Level: 10 Points: 2,173, Level: 10 Points: 2,173, Level: 10
Thanks: Gave 2, Got 2
Samsung engineer came to my house and after speaking with just about everyone in the samsung engineering team, basically advised me to take it back to where I purchased the TV. I subsequently changed it for the same model and low a behold same issue!!!! At=s this was the last straw I got my money back and have recently purchased the slightly smaller 50 inch Panny VT20. No issues found so far.....
Old 25-06-2010, 12:53 PM   #22
1,634, Level: 9
Given the issues and workaround i.e. turning the Amp on first - does the issue exhibit itself when using pass through mode i.e. Amp in standby and just repeating the signal to the TV?
Old 25-06-2010, 1:12 PM   #23
thfccambs's Avatar
32,027, Level: 43
Activity: 3.8%
Looks like there may well be a few onkyo amps up for sale soon.
Gutted if i have the same problems with my Sammy 63" and onkyo 606.
Old 26-06-2010, 10:54 AM   #24
1,634, Level: 9
Fyi, I currently have a Samsung UE55B7020 and an Onkyo 608 and it works fine. I've never had handshake issues, whether using pass thru mode or full Amp mode. Albeit, I don't have any HDMI 1.4 blu-ray players plugged into it but it sounds like people are just having problems with the connection from the 608 to the TV itself. I really think it's more a TV issue with the new Samsung 3D compatible TVs. I was just about to purchase but want Samsung to iron out the issues first. Hopefully a new firmware is on it's way. Maybe they'll even update support to 1.4a (current 1.4 support only)
Old 28-06-2010, 7:54 PM   #25
thfccambs's Avatar
32,027, Level: 43
Activity: 3.8%
Looks like i may well need to buy a new Amp
Dear Jeff
thank you very much for your message and your interest in ONKYO products. You have reached the support/help desk for ONKYO Europe.
For playback of "3D video" is necessary the HDMI version 1.4.
Unfortunately the TX-SR 606 has the HDMI version 1.3.
Also it is unfortunately not possible to upgrade the TX-SR 606 in this issue.
For technical hotline and service (repair, spare parts, manuals, updates,upgrades) please get in contact with:
GenServe (GTS) Limited
11 Caen View
Rushy Platt
Swindon
SN5 8WQ
Tel: +44 (0) 1793 886 333
Fax: +44 (0) 1793 886 323
info@genserve.co.uk
Anu ideas of a good priced 1.4 3D amp?
Old 29-06-2010, 4:50 AM   #26
891, Level: 6
Points: 891, Level: 6 Points: 891, Level: 6 Points: 891, Level: 6
The Onkyo 608.
Old 29-06-2010, 6:54 PM   #27
NE0 NE0 is offline
NE0's Avatar
1,504, Level: 8
LATEST UPDATE
Samsung have released firmware 1014.3 on 28th june
via their website.
It took a while for the download, busy traffic I guess! but nonetheless, early indications are its a fix for the onkyo 608 issue.
Samsung have a tendancy not to show a change log so its difficult to be sure that it applies.
However, BEFORE I installed it, I rechecked I could create the ERROR and I managed to do it repeatedly using version 1013, so I know the error exists.
AFTER install of the 1014.3, I tried several times to recreate the error and so far it all WORKS fine!
If I turn off the 608, and put the TV in standby, Then procede to turn on the TV, followed by the AV receiver, the source menu shows HDMI2 each time without causing an error. I've tried x8 and the error has not come up.
I'd like to say they've fixed it........
For those willing to download, let us know if yours is fixed to and I'll EDIT the title to include FIXED
NE0
Old 29-06-2010, 7:22 PM   #28
thfccambs's Avatar
32,027, Level: 43
Activity: 3.8%
Originally Posted by NE0 View Post
LATEST UPDATE
via their website.
NE0
Excellent news for 608 users, hopefully this will work with 606 also.
Old 29-06-2010, 8:52 PM   #29
635, Level: 5
Just applied the update - seems to be sorted..
Old 29-06-2010, 10:00 PM   #30
1,634, Level: 9
Excellent news, I guess I'll be ordering my Samsung TV this weekend!
Powered by
 Latest popular product prices
LG DM2350D-PZM
8 prices from
 £222.92 Click to show/hide the offers
LG DM2780D
4 prices from
 £259.99 Click to show/hide the offers
LG 42PW450T
4 prices from
 £399.95 Click to show/hide the offers
Toshiba 40TL868G
10 prices from
 £429.00 Click to show/hide the offers
Panasonic Viera TX-P42UT30B
5 prices from
 £449.99 Click to show/hide the offers
Sharp Aquos LC-40LE831E
5 prices from
 £499.99 Click to show/hide the offers
Toshiba 46TL868G
11 prices from
 £624.98 Click to show/hide the offers
Sony Bravia KDL-40HX723
8 prices from
 £629.00 Click to show/hide the offers
 Updated February 8th at 3:30pm. Prices include delivery.
